Page 3 of 3 FirstFirst 1 2 3
Results 21 to 24 of 24
  1. #21
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, Vista and XP Pro
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    852
    abgailpp, please don't do multiple posts in different forums. I've already answered you question in another forum.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
  2. #22
    Junior Member
    Civil 3D 2012
    Apr 2012
    11
    Quote Originally Posted by Tyke View Post
    I have a survey of an area that I need to get into SolidWorks so that a model of the area can be made of it.
    I have contours as polylines or points with X,Y,Z coordinates and I can create a surface or a collection of 3D faces. I can also create a 3D solid and export it from AutoCAD Civil 3D in STL format.
    Does anybody have any idea how I can best get my data into SolidWorks so that it can worked up into a model?
    I do not have SolidWorks, I must just give my data on to someone who does have SolidWorks, so that he can do something with it. I'm a pure AutoCAD/MAP/Civil man.
    Hi!
    I´m having problem with creating stl file from surface. I need to import stl in another program for rockfalls.
    I have create surface from contours, then extract faces, extrude them, union and I got solid..
    I have export solid like stl file...
    But in another program my surface is not smooth, like something went wrong while exporting stl, because in autocad civil 3D 2012 everything looks good.
    I have found out how I can increase facetres to 10, but It has not affect to my stl file.
    If there is some another parameter for better resolution of stl files?
    Thanks for help!
  3. #23
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    Quote Originally Posted by tonka View Post
    Hi!
    Thanks for help!
    When you do Save-As with solidworks and change the file type to .stl an options button will become available. Click options and you will have a few options for the resolution. You can pick Course of Fine or Custom. Depending on how large the file is you will have to be careful. For smaller parts with high levels of detail I will change the angle to 1degree. For larger parts like a car i might need to use 3 or 4 degrees.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
  4. #24
    Junior Member
    Civil 3D 2012
    Apr 2012
    11
    Thank You for your reply!
    I am really need help.
    I am working in AutoCad Civil 3d 2012 and there is not that options button. So I think I need change some other options except facetres..I also try to incrase SPLINESEGS, ISOLINES, VIEWRES, but that did not change resolution of exported stl file.
    Do You know some others properties?
  1. Creating 3D terrain surface question....
    By Dman2900 in forum 3D Modelling
    Last Post: 8th Dec 2009, 10:03 pm
  2. terrain model
    By rookie37 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th May 2008, 06:10 am
  3. Creating Terrain surfaces in AutoCAD
    By ericmiles in forum AutoCAD 3D Modelling & Rendering
    Last Post: 2nd Apr 2008, 10:15 pm
  4. creating a terrain
    By gib65 in forum AutoCAD Drawing Management & Output
    Last Post: 5th Feb 2008, 05:43 am
  5. creating a Terrain!
    By alessandro754 in forum AutoCAD Drawing Management & Output
    Last Post: 15th Sep 2006, 05:04 pm
