RMS Posted November 24, 2010 Share Posted November 24, 2010 Hey Guys! I need some help here, does anyone have an example of using a form with buttons? For example I would like to make a form with a button that would then pass a string value to a command. Thanks, Rob Quote Link to comment Share on other sites More sharing options...
SEANT Posted November 24, 2010 Share Posted November 24, 2010 I haven’t used a lot of forms while automating AutoCAD via .NET, and absolutely none with VB.NET, unfortunately. If it is any help, though, I do have the source code for one “forms” based C# routine posted here: http://www.cadtutor.net/forum/showthread.php?25414 It was a fairly early effort so the coding may not be all that proficient. Quote Link to comment Share on other sites More sharing options...
Jeff H Posted November 24, 2010 Share Posted November 24, 2010 <[color=#2b91af]CommandMethod[/color]([color=#a31515]"ShowForm"[/color])> _ [color=blue]Public[/color] [color=blue]Sub[/color] ShowForm() [color=blue]Dim[/color] frm [color=blue]As[/color] [color=blue]New[/color] [color=#2b91af]Form1[/color] [color=#2b91af]Application[/color].ShowModelessDialog(frm) [color=blue]End[/color] [color=blue]Sub[/color] Code behind form if it modeless remeber to lock the document [color=blue]Imports[/color] Autodesk.AutoCAD.Runtime [color=blue]Imports[/color] Autodesk.AutoCAD.ApplicationServices [color=blue]Imports[/color] Autodesk.AutoCAD.DatabaseServices [color=blue]Imports[/color] Autodesk.AutoCAD.EditorInput [color=blue]Public[/color] [color=blue]Class[/color] [color=#2b91af]Form1[/color] [color=blue]Private[/color] [color=blue]Sub[/color] Button1_Click([color=blue]ByVal[/color] sender [color=blue]As[/color] System.[color=#2b91af]Object[/color], [color=blue]ByVal[/color] e [color=blue]As[/color] System.[color=#2b91af]EventArgs[/color]) [color=blue]Handles[/color] Button1.Click [color=blue]Dim[/color] doc [color=blue]As[/color] [color=#2b91af]Document[/color] = [color=#2b91af]Application[/color].DocumentManager.MdiActiveDocument [color=blue]Dim[/color] ed [color=blue]As[/color] [color=#2b91af]Editor[/color] = doc.Editor [color=blue]Using[/color] docloc [color=blue]As[/color] [color=#2b91af]DocumentLock[/color] = doc.LockDocument ed.WriteMessage(vbCrLf & [color=#a31515]"You pressed a button"[/color]) [color=blue]End[/color] [color=blue]Using[/color] [color=blue]End[/color] [color=blue]Sub[/color] [color=blue]End[/color] [color=blue]Class[/color] Quote Link to comment Share on other sites More sharing options...
RMS Posted November 25, 2010 Author Share Posted November 25, 2010 Thanks a bunch guys! I am off and running now.......... Quote Link to comment Share on other sites More sharing options...
bsamc2000 Posted December 1, 2010 Share Posted December 1, 2010 I use very similar coding except I use a error handler. It just helps hunt down errors. [font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff]Try [/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2][/size][/font][/size][/font][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff] Dim[/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2] cForm [/size][/font][/size][/font][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff]As[/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2] [/size][/font][/size][/font][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff]New[/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2] [/size][/font][/size][/font][font=Consolas][size=2][color=#2b91af][font=Consolas][size=2][color=#2b91af][font=Consolas][size=2][color=#2b91af]frmTitleblock [/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2][/size][/font][/size][/font][font=Consolas][size=2][color=#2b91af][font=Consolas][size=2][color=#2b91af][font=Consolas][size=2][color=#2b91af] Application[/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2].ShowModalDialog(cForm) [/size][/font][/size][/font][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff]Catch[/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2] ex [/size][/font][/size][/font][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff]As[/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2] [/size][/font][/size][/font][font=Consolas][size=2][color=#2b91af][font=Consolas][size=2][color=#2b91af][font=Consolas][size=2][color=#2b91af]Exception [/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2] MsgBox(ex.Message, [/size][/font][/size][/font][font=Consolas][size=2][color=#2b91af][font=Consolas][size=2][color=#2b91af][font=Consolas][size=2][color=#2b91af]MsgBoxStyle[/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2].Critical) [/size][/font][/size][/font][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff]End[/color][/size][/font][/color][/size][/font][/color][/size][/font][font=Consolas][size=2][font=Consolas][size=2] [/size][/font][/size][/font][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff][font=Consolas][size=2][color=#0000ff]Try [/color][/size][/font][/color][/size][/font][/color][/size][/font] Quote Link to comment Share on other sites More sharing options...
fixo Posted December 3, 2010 Share Posted December 3, 2010 (edited) Hey Guys! I need some help here, does anyone have an example of using a form with buttons? For example I would like to make a form with a button that would then pass a string value to a command. Thanks, Rob Try this quick example too ''Project FormVB ''Form module code ''Form1.vb ''============================'' Imports System Imports System.Collections.Generic Imports System.Text Imports System.IO Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Runtime Imports Autodesk.AutoCAD.Geometry Imports System.Windows.Forms Public Class Form1 Private Sub btnAcad_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnAcad.Click Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument Dim db As Database = doc.Database Dim ed As Editor = doc.Editor Dim usered As EditorUserInteraction = ed.StartUserInteraction(Me) Using (usered) Dim tr As Transaction = db.TransactionManager.StartTransaction Try If (Me.Modal) Then Dim docloc As DocumentLock = doc.LockDocument Using (docloc) Me.Hide() Using (tr) ' Do your other things here e.g. pick point Dim opt As PromptPointOptions = New PromptPointOptions(vbCr & "Pick point :") Dim res As PromptPointResult = ed.GetPoint(opt) If (res.Status <> PromptStatus.OK) Then ed.WriteMessage(vbCr & "User input error. Exit") ElseIf (res.Status = PromptStatus.Cancel) Then ed.WriteMessage(vbCr & "Interrupted by user input. Exit") Return End If Dim pt As Point3d = res.Value Dim txt As DBText = New DBText txt.SetDatabaseDefaults() txt.Position = pt txt.TextString = Me.txtCommand.Text txt.HorizontalMode = TextHorizontalMode.TextCenter txt.VerticalMode = TextVerticalMode.TextVerticalMid txt.AlignmentPoint = pt Dim btr As BlockTableRecord = CType(tr.GetObject(db.CurrentSpaceId, OpenMode.ForWrite), BlockTableRecord) btr.AppendEntity(txt) tr.AddNewlyCreatedDBObject(txt, True) ed.Regen() tr.Commit() End Using End Using End If Catch ex As System.Exception Autodesk.AutoCAD.ApplicationServices.Application.ShowAlertDialog(ex.Message) Finally usered.End() ' Display the form again if you need: 'If Me.Visible = False Then Me.Show() ''otherwise close form Me.Close() End Try End Using End Sub Private Sub Form1_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load Me.txtCommand.Text = "Type the text here" Me.txtCommand.Focus() End Sub End Class Add this class to project ''RunApp.vb ''==================================='' Imports Autodesk.AutoCAD.ApplicationServices Imports Autodesk.AutoCAD.DatabaseServices Imports Autodesk.AutoCAD.EditorInput Imports Autodesk.AutoCAD.Runtime Imports System.Windows.Forms <Assembly: CommandClass(GetType(FormVB.RunApp))> Namespace FormVB Public Class RunApp <CommandMethod("RunMe", CommandFlags.Modal)> _ Public Shared Sub InitForm() Dim frm As New Form1 Dim ed As Editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor ed.WriteMessage("InitForm command started") Dim result As DialogResult = Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(frm) End Sub End Class End Namespace Netload the project and type RUNME in the command line ~'J'~ Edited December 3, 2010 by fixo spell check Quote Link to comment Share on other sites More sharing options...
stingrey3 Posted December 14, 2010 Share Posted December 14, 2010 What References need to be added to run this app? Quote Link to comment Share on other sites More sharing options...
fixo Posted December 14, 2010 Share Posted December 14, 2010 Please, deep into this project you can see all references in there http://through-the-interface.typepad.com/through_the_interface/files/TypeViewerSource.zip ~'J'~ Quote Link to comment Share on other sites More sharing options...
