Block lineweight issues
nicnicman
When I insert (drag and drop from tool palette) a block the lineweight does not change to the lineweight of the active layer. This is happening with a few of my blocks although not all of them. All the blocks were drawn on the default layer 0. It seems no matter which layer the blocks are placed on the lineweights always stay the same.
Has anyone else had this issue? What can I do to correct it? Thanks for any suggestions.
Well I found my own answer. For some reason some of the lines on the bad blocks had lineweights assigned to them rather than the lineweight being set to "by block". Thanks anyways. Sorry to bother everyone.
