supragod98 Posted December 1, 2010 Share Posted December 1, 2010 I am getting the following error when qsaving a file "Error opening Named Objects Dictionary getting Id in dictionary, eWasOpenForWrite" I do not know what this is and what it means. Can anyone tell me what this is and what causes this? I am running AutoCad 2010 MEP on Windows 7 Professional 32bit. Thanks Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 1, 2010 Share Posted December 1, 2010 Maybe there is an error in your drawing. Did you try to run an Audit on it? Quote Link to comment Share on other sites More sharing options...
supragod98 Posted December 1, 2010 Author Share Posted December 1, 2010 Yes I have done an audit on the file and still get the error when saving. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 1, 2010 Share Posted December 1, 2010 Try the Audit command again but this time when you first run it say "No" when prompted to fix any errors detected. Assuming errors are detected run Audit a second time and respond "Yes" to fixing errors. What happens? Quote Link to comment Share on other sites More sharing options...
supragod98 Posted December 2, 2010 Author Share Posted December 2, 2010 Ran an audit and chose no to fixing any errors and it shows audit detecting 0 errors. Still get the same error message when qsaving. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 2, 2010 Share Posted December 2, 2010 We're talking just this one file having the error right? Quote Link to comment Share on other sites More sharing options...
supragod98 Posted December 2, 2010 Author Share Posted December 2, 2010 That would be correct. I just confirmed this with another file. It does not give me an error when qsave command is initiated. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 2, 2010 Share Posted December 2, 2010 Then you have a corrupted file of some sort. Maybe you can WBlock everything and put it in a new drawing and delete the old one. Quote Link to comment Share on other sites More sharing options...
supragod98 Posted December 3, 2010 Author Share Posted December 3, 2010 This sort of worked. It seems it may have something to do with xref's. When I wblock'd all the items out of the drawing into a new drawing I didnt get the error. As soon as I xref'd back in my backgrounds and such I started to get the error again. I went through and checked the other drawings and individually they would not produce the error nor did Autocad detect errors through the audit command. The other thing is it would only happen when I load more then 1 xref. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 3, 2010 Share Posted December 3, 2010 So we now have another variable then...xrefs. How many? Quote Link to comment Share on other sites More sharing options...
supragod98 Posted December 3, 2010 Author Share Posted December 3, 2010 When I attache just 1 of any of the xrefs for this drawing I do not get the qsave error. As soon as a second xref is attached the qsave error returns. The error does not go away even after I do an audit and detach all xrefs. Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 3, 2010 Share Posted December 3, 2010 Have you considered running the Repair option? Quote Link to comment Share on other sites More sharing options...
supragod98 Posted December 3, 2010 Author Share Posted December 3, 2010 Repair option? Not familiar with it unless your talking about recover? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 3, 2010 Share Posted December 3, 2010 No, not Recover. Repair...for repairing your installation of AutoCAD MEP. You should be able to find it under the Windows Add/Remove Programs option. Quote Link to comment Share on other sites More sharing options...
