Do you use imperial units?
I tried my metric model, and it won't map my rendering materials correctly. Not sure if it still has the problem, I haven't tried it again.
final_Project_2_Counter_Top_4_Neon_-_Standard(3)_2010-12-05_12-57-35.jpg3d Rendering By autodesk in its beta stage but it works great
http://neon.labs.autodesk.com/
thats the autodesk labs Project and you just upload your dwg files to autodesk and render
all you need to do is export your dwg into etransmit files with the
etransmit command
and then upload the zip file
and choose the quality and then the resolution
autodesk's Servers/ Super computers will render everything precisely and in 1/4 1/8 1/16 the time it will take a core 2 duo and most core i7s
its awesome give it a try
you must have at least 1 named view and
1 light in order to render
so create a camera and a light if you dont have one
ive got a sample file
its simple but its rendered at 1920 * 1080
and it took a shorter time period than it would take my core i7 laptop
i use my own template with units set to architectural feet and inches
with 0'0" precision
did you export your file into the etransmit format with the etransmit command?
Yes, it gives me the rendering result.
But the rendering material sizes are all wrong.
i dont know how to help, all my renderings turn out ok except some are a bit off on the colors
Now you know why it's called a "beta".
Interesting.....
Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
- http://f700es.deviantart.com/gallery/ - - http://cad-guy.tumblr.com/ -
