toddcl Posted December 7, 2010 Share Posted December 7, 2010 I believe this is the default setting when importing points from a txt file to Civil they go to layer 0 how do I change it so they import on to the current layer? Thanks, Quote Link to comment Share on other sites More sharing options...
lpseifert Posted December 7, 2010 Share Posted December 7, 2010 Set the layer you want the points on current prior to importing them Quote Link to comment Share on other sites More sharing options...
toddcl Posted December 7, 2010 Author Share Posted December 7, 2010 Actually I was able to find where you need to change the setting is in Edit Command Settings, the default for importing points is layer 0 no matter what layer you are on. to Quote Link to comment Share on other sites More sharing options...
toddcl Posted December 7, 2010 Author Share Posted December 7, 2010 This is such a pain in the butt switching all of the styles that were set up in 2008 to 2011 Quote Link to comment Share on other sites More sharing options...
BIGAL Posted December 8, 2010 Share Posted December 8, 2010 Have you tried opening up an existing 2008 dwg and a new 2011 dwg and using "Tool space Settings" dragging the point styles for the 2008 dwg into the 2011 dwg ? Probably drag all styles and make a new 2011.dwt Quote Link to comment Share on other sites More sharing options...
toddcl Posted December 8, 2010 Author Share Posted December 8, 2010 Actually thats true you need to open a 2008 dwg with 2011 and it does the up converstion then you just have to drag your styles into the new 2011 dwg Quote Link to comment Share on other sites More sharing options...
