Results 1 to 3 of 3
    Senior Member harilalmn's Avatar
    harilalmn's Computer Details
    Win XP
    Architectural
    harilalmn's Discipline Details
    CAD Manager
    Architectural
    AutoCAD 2010
    Aug 2010
    Bangalore, India
    115
    Question SSM - Sheet Rename layout and Rename File Options are disabled
    Hi All,
    I had some previously created drawing files.
    I was trying to setup a sheet set, by creating a blank sheet set and then by using the option "Import Layout as Sheet". I imported all the sheets. Then I had to edit the Sheet title and sheet number in each sheet's properties. However, the Rename Options to rename layout tab and the file seems to be disabled for all the sheets in this sheet set. (Please see the attachment)
    What could be wrong?
    Super Member ScribbleJ's Avatar
    ScribbleJ's Computer Details
    Windows 7
    Dell Precision T3500
    Intel(R) Xeon(R) CPU W3530 @ 2.8GHz 2800 Mhz
    12 gig
    Nvidia Quadro 600
    237 GB
    Main: Dell 2408 Aux: Dell 1703FP
    Civil
    ScribbleJ's Discipline Details
    Civil Design Tech for Water / Waste Water Industry.
    Civil
    Roadway designs, water and waste-water treatment systems and water distribution systems.
    Civil 3D 2011
    Dec 2008
    Rancho Cordova, CA
    539
    If the files are opened this will happen. Also if someone else is working within the sheet set then this will lock those options as well.
    Calvin
    Soli Deo Gloria
    Win XP
    Architectural
    CAD Manager
    Architectural
    AutoCAD 2010
    Aug 2010
    Bangalore, India
    115
    Thankyou for your quick response SribbleJ...
    But the files were not opened anywhere in the network and nobody else was working on them...
    I confirmed that;
    1. Nobody had the files opened (None of the sheets had a lock icon on it)
    2. No one else was working on sheet set
    3. The properties of the files in the folder was not read only
    Now I don't know why this happens...
  1. layout tab rename with block attribute value
    By super_troy in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Nov 2011, 08:05 pm
  2. Can VBA be used to Rename a Layout Tab?
    By muck in forum .NET, ObjectARX & VBA
    Last Post: 26th Jul 2010, 08:55 am
  3. batch rename a layout
    By The Courage Dog in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Mar 2010, 10:10 pm
  4. Rename all Layout Tabs
    By Bill Tillman in forum AutoCAD Drawing Management & Output
    Last Post: 20th Aug 2009, 11:08 pm
Tags for this Thread
