do you want to save dialog position after close ?
look at this code:
http://www.cadtutor.net/forum/showth...ne-can-test-it
and
http://www.cadtutor.net/forum/showth...indow-position
kruuger
Hi,
I need to move a DCL box out of the middle of the screen, is there a way to do that?
Thanks for your help.
Shawndoe
look at this code:
and
kruuger
Hi,
That did it thanks alot.
Have a good one.
Shawndoe
I have looked at this thread, and the file from kruuger, however I am still lost on dcl box placement. Is there a way to direct the where the dialog box is placed on the screen when it opens ? Anyone willing to share....
You can specify an initial position in screen coordinates, then the position of the dialog will be returned bythe done_dialog function, which you can store for the next time.
I'll post an example if you wish![]()
Lee Mac Programming
Just another Swamper
Ok, so I couldn't resist making an example
Save the following as 'test.dcl' in a Support Path:Code:(defun c:test ( / *error* dcl dch ) ;; Example by Lee Mac 2011 - www.lee-mac.com ;; Demonstrates how to remember a dialog screen ;; position for next use. ;; Requires accompanying file: test.dcl to be ;; in AutoCAD Support Path. (defun *error* ( msg ) (if dch (unload_dialog dch)) (or (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*") (princ (strcat "\n** Error: " msg " **"))) (princ) ) (cond ( (not (and (setq dcl (findfile "test.dcl")) (< 0 (setq dch (load_dialog dcl))) ) ) (princ "\n** DCL File not found **") ) ( (not (new_dialog "test" dch "" (cond ( *screenpoint* ) ( '(-1 -1) )))) (setq dch (unload_dialog dch)) (princ "\n** Dialog could not be Loaded **") ) (t (action_tile "accept" "(setq *screenpoint* (done_dialog 1))") (start_dialog) (setq dch (unload_dialog dch)) ) ) (princ) )
Position is stored as a global variable in this case, but the code could be altered to convert the screen position into a string and store it in the registry between drawing sessions.Code:test : dialog { label = "Test Dialog"; spacer; : text { label = "Move me"; alignment = centered; } spacer; : button { key = "accept"; is_default = true; label = "I'm Done"; } }
Enjoy!
Lee
Lee Mac Programming
In fact, I have just decided to add this topic to my website:
http://lee-mac.com/dialogposition.html
Lee Mac Programming
