Plane and sketch visibility
Hawk646
Could someone tell me if there is a way to keep all planes and or sketches invisible except the one being created. ie I create a plane in an assembly to create a new part on and all planes in the assembly become visible.
I am using a base sketch for most of the parts and that sketch contains many planes, plus the planes used to modify the parts. The screen practally turns yellow with planes when I creat a new plane.
Any suggetions will be appreciated.
weird, that doesn't happen to me, when i create a plane it becomes visible of course, but the rest stay invisible, so i don't know what to tell you
I think this might be because the planes are visible in the part file itself, so everytime the 'User Work Plane' option becomes ticked (which it will when you create a new plane i the assembly) they all become visible again.
If you turn the visibility of the planes of in the part file itself, this will stop that from happening - of course now you won't be able to see the planes you need to model with and will to control them individually
