Usually when you print, there is an option to PLOT TO FILE. If you checked it, it will plot your drawing to PLT file.
Too bad I don't have 2000 or else I can take a screenshot.
Is there a simple way to convert .dwg files to .plt files?
And does anyone have an idea how to print ansi d and e
size .dwg files?
Is there anyplace you can go with a .dwg file or .plt
file and have them printed?![]()
Try this link:
http://handouts.tamu.edu/pdf/Print2000.pdf
On page 4 of 7 scroll to item 8. It's heading is: Make sure you are not plotting to a file. It actually tells you what not to set...ignore the advice and you'll be able to generate a .plt file. It's not a matter of converting a .dwg to a .plt as you might think.
Good luck. Let's us know if you are sucessful.
