Creating a topographic map from Survey Data
celittle
Hello All,
Thank you for welcoming me into your community. I am in quite a pickle. I have to create a 3D topographic map from survey data, using polylines and interpolation. The contour interval is 2'. The survey data is already in a dwg file (elevation and postion). I am using AutoCAD 2010. My knowledge in AutoCAD is really small and I really don't know how to start. Later in the project I have to cut a road in the topograph and measure the amount of soil I have removed. It is due this evening and I don't know what to do. Please help. Thank you in advance for your response
You really should be using a civil program not plain AutoCAD to do this. Isn't it a bit late in the game to be popping in with this question? Due tonight? Yikes!
Try a Search of the forums using the words create topo map and see what it brings up. You definitely have your work cut out for you.
That's the feeling I get, but I have to used AutoCAD
AutoCAD does not have a built-in capability to interpolate contours from spot elevations. You would need some sort of add-on program or you would have to extract all the elevations (with their northing and easting coordinates) to a file that could be used by a topographic program to do it. Then you would have to get the contours out of the program and back into AutoCAD and use them to create a solid. At least that's the way I see it.
Hpw many spot elevations are you working with?
Is it possible also get additional interpolated points, connect those points with 3D polylines and create a surface from there. I have an short application for interpolation. I am running it, but I don't know where the data is ending up.
What application? Do you know what the file type is for the data?
Here is the application code
;; This program was written to interpolate even contour intervals
;; from data provided by a survey.
;; Written for Civil Engineering Graphics 170 class project.
;; Kent Hobson
;; Department of Mechanical Engineering
;; University of Wisconsin - Madison
;; October, 14 1992 - 2001
;; Standard disclaimers apply: I am not responsible for anything that goes
;; wrong with this program. If you can not make
;; this autolisp program work, then do it by hand.
(defun datumchk ()
;;calc delta elevation 1*********
;;which datum is larger
(if (> p1ee p2ee)
(setq diff1 (- p1ee p2ee))
(setq newc (fix p1ee))
(setq refel p1ee)
(setq lowel p2ee)
(calccnt p1eb p2eb refel lowel)
(setq diff1 (- p2ee p1ee))
(setq newc (fix p2ee))
(setq refel p2ee)
(setq lowel p1ee)
(calccnt p2eb p1eb refel lowel)
;;calc delta elevation 2***********
(if (> p1ee p3ee)
(setq diff1 (- p1ee p3ee))
(setq refel p1ee)
(setq lowel p3ee)
(calccnt p1eb p3eb refel lowel)
(setq diff1 (- p3ee p1ee))
(setq newc (fix p3ee))
(setq refel p3ee)
(setq lowel p1ee)
(calccnt p3eb p1eb refel lowel)
;;calc delta elevation 3*********
(if (> p2ee p3ee)
(setq diff1 (- p2ee p3ee))
(setq refel p2ee)
(setq lowel p3ee)
(calccnt p2eb p3eb refel lowel)
(setq diff1 (- p3ee p2ee))
(setq refel p3ee)
(setq lowel p2ee)
(calccnt p3eb p2eb refel lowel)
;;select the next set
(setq ans (getstring (strcat "\nDo another set?
"y" ">\\n ")))
(cond ((= ans "y") (gdata))
((= ans "Y") (gdata))
((= ans "") (gdata))
((= ans "n") (princ))
((= ans "N") (princ))
(t nil)
;_____________________________________________________________
;;find the first contour to print
(defun calccnt (a b hel lel)
(if (/= (rem newc ci) 0.0)
(setq rem_v (rem newc ci))
(setq newc (fix (- newc rem_v)))
(while (>= newc lel)
(drawpt a b hel lel newc)
; (princ "\nnewc - ci ")
; (princ "newc ")
; (princ newc )
(setq newc (fix (- newc ci)))
;_____________________________________________________________________
(defun drawpt (a b hel lel newc)
;;calc the distance between data points
(setq d (distance a b))
;(princ "distance = ")
;(princ d)
;;calc the angle between data points
(setq pangle (angle a b))
;(princ "newc = ")
;(princ newc)
;;calc a real elevation difference to be plotted
(setq zvalue newc)
(setq zpt (rtos zvalue 2 4))
;(princ "\nzvalue = ")
;(princ zvalue)
;;interpolate the location of the new contour point
(setq diff2 (- hel newc))
(if (/= diff1 0.0000)
(setq deltax (/ (* diff2 d) diff1))
(setq deltax 0.0001)
;(princ "deltax = ")
;(princ deltax)
;;plot a new point and write elevation text
(setq startpt (polar a pangle deltax))
(setq xpt (rtos (car startpt) 2 4))
(setq ypt (rtos (cadr startpt)2 4))
;(princ "\n\n\nthis point is for plot")
(command "point"
".xy"
(setq plotpt startpt)
(setq 3pt (* 12 zvalue))
;(princ "\n3pt = ")
;(princ 3pt)
(command "text"
".xy"
(setq txtpt (polar plotpt 0.0 (+ r 0.2)))
(setq mpt 3pt)
"0.0"
(setq prntxt newc)
;get contour interval
(defun getci ()
(setq ci (getstring "\nEnter the Contour Interval: "))
(setq ci (atof ci))
(setvar "pdmode" 35)
(setvar "cmdecho" 0)
(command "layer"
"n"
"1_tmp_data"
"c"
"6"
"1_tmp_data"
"s"
"1_tmp_data"
"off"
"1_tmp_data"
"y"
;enter datum information for first point from contour map
(defun gdata ()
(graphscr)
(initget (+ 1 4))
(setq p1 (entsel "\nSelect data point 1:"))
(setq p1data (entget (car p1)))
(setq p1eb (cdr(assoc 10 p1data)))
(setq r (cdr(assoc 40 p1data)))
;;change the color
(setq x1r (polar p1eb 3.14159 r))
(command "chprop"
(ssget (osnap x1r "qua"))
"c"
"red"
; (princ bdata)
(setq p1e (entsel "\nSelect the elevation of pt 1: "))
(setq p1elev (entget (car p1e)))
(setq p1ee (cdr(assoc 1 p1elev)))
(setq p1el (cdr(assoc 10 p1elev)))
(setq p1ee (atof p1ee))
;; pick the second datum point from the contour map
(setq p2 (entsel "\nSelect data point 2:"))
(setq p2data (entget (car p2)))
(setq p2eb (cdr(assoc 10 p2data)))
;;change the color
(setq x2r (polar p2eb 3.14159 r))
(command "chprop"
(ssget (osnap x2r "qua"))
"c"
"red"
(setq p2e (entsel "\nSelect the elevation of pt 2: "))
(setq p2elev (entget (car p2e)))
(setq p2ee (cdr(assoc 1 p2elev)))
(setq p2ee (atof p2ee))
;; pick the third datum point from the contour map
(setq p3 (entsel "\nSelect data point 3:"))
(setq p3data (entget (car p3)))
(setq p3eb (cdr(assoc 10 p3data)))
;;change the color
(setq x2r (polar p3eb 3.14159 r))
(command "chprop"
"c"
"red"
(setq p3e (entsel "\nSelect the elevation of pt 3: "))
(setq p3elev (entget (car p3e)))
(setq p3ee (cdr(assoc 1 p3elev)))
(setq p3ee (atof p3ee))
(datumchk)
; Run it
(defun C:int ()
(getci)
(gdata)
Well it looked promising anyway.
I'm only half-blind. One eye is totally shot. That's why it takes me twice as long to read a post and code just makes my visual orb go all moist. LOL
  • 2 weeks later...
Lol, hey well if you get it working with autocad, leave a messege on how you did it, i too have been wanting to do this with autocad, but many have said its impossible without other software, 1 thing ive heard of is Rhino, but it cost around 200 i think
