Page 6 of 8 FirstFirst ... 4 5 6 7 8 LastLast
Results 51 to 60 of 76
  1. #51
    Full Member
    AutoCAD 2010
    Apr 2011
    38
    After looking at the adjacent coordinates I see most of the y coordinates start with 7833...so I tried this and my tree was placed in the lower left corner by the other trees so I am assuming that this was the type-O error....
  2. #52
    Full Member
    AutoCAD 2010
    Apr 2011
    38
    I am working on the Oleson Village. When I make SW Washington Street connect with SW Oleson Road at the Benchmark, SW Olsen Road ends up with a 84' ROW. All of my other roads have a 50' ROW except for SW Davis Court has a 40' ROW. Is this right or does SW Oleson Road have to have a 50' ROW too. If SW Oleson Road has a 50' ROW, then Washington does not intersect at the Benchmark....
  3. #53
    Full Member
    AutoCAD 2010
    Apr 2011
    38
    Hello to someone out there who cares!!!
    I am still working on the Oleson Village and hoping someone can answer my questions I posted above and also the following questions:
    1. What layer are the Roads: SW Alden Street, SW Daves Court, SW Kensington Place, SW Washington Street, Sw Oleson Road, and the extention of SW 85th Ave. on.
    I drew them on the yellow Border layer because of seeing other peoples' postings...but I am not sure this is right
    2. What right of way label does SW Oleson Road get...50' ???
    3. What layer is the Title Block drawn on? The instructions say to activate the layer called TRIM. There was no layer in the instructions called Trim, so I made one
    with the color white and continuous line type. Then drew the 24X36 landscape border on it. I then drew the inside border. The instructions tell me to move
    the "new lines to the correct layer." What layer is this? I moved the inside border lines onto the Yellow Border layer and left the Outside Border lines on the
    Trim layer. Then I am to draw the title block...does this title block go on the yellow border layer or the red Title layer??? I am assuming that the title block it
    drawn on the yellow border layer and then the title-Olseon Village is placed in the titile block using the red title layer....Is this right...
    Thank You to anyone that can help!!!
  4. #54
    Full Member
    AutoCAD 2010
    Apr 2011
    38
    I think I figured the answer to question 1. These roads should be drawn on the ROW layer. Meaning Right of Way not row like row your boat....
    I still need help with the other questions thou. Also when I Zoom Extend my drawing the image vanishes. I have no idea why?
  5. #55
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    The zoom extends command makes every thing small in relation to the limits. This is put in to get the coordinates correct for the benchmark location.
    I am working on your other answers now.
  6. #56
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Quote Originally Posted by Megaforce1 View Post
    Hello Car 5858:
    I think I got it..the decimal units can denote any value, in this case a decimal unit is one foot; therefore 7.5 is egual to 7.5 feet...thankyou for you patience...I am sure to call on them again...this site is a life saver...thanks
    Yes
    Hello I am working on the Olsen Village. Can someone tell me what layer the the first 2 roads as to be on. (i.e. SW 85th Ave and SW Village Lane) When I look at others drawings that are posted on this site, they appear cyan. I am assuming the layer is boundary (with pantom lines - cyan) and then the sidewalks layer is also cyan so they kind of look the same. Also what layer is the 1' buffer between the right of way and the beginning of the sidewalk drawn on. Thanks
    ROW Right of way
    I have drawn the 1' buffer with the sidewalk layer, the 6' sidewalk on the sidewalk layer, and the 3' parking strip on the curb layer....Is this correct???? Thanks again!
    Also is the 3' parking area offset from the right of way or offset from the sidewalk??
    Message: In the Oleson Village, I drew the first 2 roads on the boundary layer. I then offset the 1' buffer on the outside of the roads and placed this line on the sidewalk layer. Then I offset the 6' sidewalk to the outside off the buffer line. Then I offset the 3' parking area from the inside sidewalk line and placed this line onto the curb layer....I am really hoping this is right...it is confusing in the instructions as it sounds like you have to jump the curb to park....
    REPLY FROM PENN FOSTER:
    Your drawing is correct...Actually the "parking strip" is just a small grassy area next to the sidewalk (in a typical neighborhood where homeowners might place their trash cans for pickup as an example).
    This is a better explaination.
    I have been placing the trees and have used the list command and I have all my trees placed properly. However, Tree S44 coordinates have to been wrong as when I input them the tree is placed out in space. The coordinates that I have are: 1420986.34,786332.48 Does someone know the right coordinates for this tree. Thanks
    The correct coordinate is: 1420986.34, 783332.48
    This is what the intersection should look like.
    Roads are right of way layer.
    Border
    the "new lines to the correct layer." What layer is this? (border) I moved the inside border lines onto the Yellow Border layer and left the Outside Border lines on the
    The trim layer is the actual size of the sheet. I see that Penn Foster has changed the sheet size since I did mine. Read page 3 in the drawing set up instructions, it is easy to miss. If you still need more instruction, give the school a chance, we cant always be here to help all the time. I have to grade finals this week so I am pretty busy.
  7. #57
    Full Member
    AutoCAD 2010
    Apr 2011
    38
    Thank you to everyone on this site that helped with the oleson village....finished and handing it in...let you know how i did...thanks a million
  8. #58
    Full Member
    AutoCAD 2010
    Apr 2011
    38
    Just a quick note to let you know that I got 100% on my Oleson Village drawing...I couldn't of done it with out all the help here on this site....Thanks again....
  9. #59
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Good job.
  10. #60
    Full Member
    AutoCAD 2010
    Jul 2011
    Ellijay, GA.
    72
    hey, I,m start this project, I'm having a lots on problems understanding how things work, this is how my looks like can you help me, I feel I ready need extra help on Autocad 2010, please some one help me!!
  1. Need Help with Penn & Foster exams
    By robxfinch in forum Student Project Questions
    Last Post: 13th Nov 2012, 08:14 pm
  2. Penn and Foster Structural Project Help
    Last Post: 20th Nov 2011, 03:31 am
  3. Penn Foster Oleson Village drawing
    By black31 in forum Student Project Questions
    Last Post: 16th Dec 2010, 10:56 pm
  4. Another student with an "Oleson Village" Plat Map question.
    By Grip Grip in forum Student Project Questions
    Last Post: 29th Nov 2010, 12:15 pm
  5. Penn Foster Alumnae
    By BIGMIKE09281946 in forum Student Project Questions
    Last Post: 27th Sep 2009, 03:47 am
