What txt style are you using? can you post a sample for us to investigate?
Hi, so my company uses laser etching so we constantly have to explode TEXT so the laser can read it. Since installing AutoCAD '11 I seem to be having a problem. When I explode the TEXT it creates small lines within individual letters which almost resemble a sloppy fill pattern. This lines are throwing our laser out of whack....About 2 months ago I read of others having this problem their solution was to export the files into multiple programs how ever our time constraints are so tight that we need to keep our engineering in one program....anybody have a clue whats going on with this TEXT explode?
You might be an engineer, if you tell people that time travel does not exist..... and then 5 minutes later explain how you would build a time machine
Engineers aren't boring people, we just get excited over boring things.
Could you provide us with an image of one letter or word that was exploded where you are encountering this type of problem?
Does it look anything like this example of Times Roman text that I exploded?
Original is on the left. Exploded text in center. Exploded text separated into its individual entities on the right.
It seems that multiline fonts develop this effect. Times New Roman, Standard, etc. There is a LISP out there that can do this, im sure
this was discussed in a previous post...
http://www.cadtutor.net/forum/showth...t=explode+text
ok i have the file with examples savev as a .pdf how ever I am unsure how to post them. When I attempt to post an image it asks for a url....
Interesting program. Thanks for sharing that link JPlanera. Have you tried it out?
ok I posted the file as an attachment if you zoom in on the letter "i" you will see the wierd lines I had previously mentioned. This only happens sometimes as you can see the D is fine but the N has the same issue on a smaller scale
EDIT: Jplanera that is a pretty cool find however the normal extra crosses do not both the laser its the redundant lines that I posted that bothers it. Not only that it will do to many passes taking off to much and allowing light to leak from the panel which is no good.
