SD&PC Posted December 20, 2010 Share Posted December 20, 2010 Hi, so my company uses laser etching so we constantly have to explode TEXT so the laser can read it. Since installing AutoCAD '11 I seem to be having a problem. When I explode the TEXT it creates small lines within individual letters which almost resemble a sloppy fill pattern. This lines are throwing our laser out of whack....About 2 months ago I read of others having this problem their solution was to export the files into multiple programs how ever our time constraints are so tight that we need to keep our engineering in one program....anybody have a clue whats going on with this TEXT explode? Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 20, 2010 Share Posted December 20, 2010 What txt style are you using? can you post a sample for us to investigate? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 20, 2010 Share Posted December 20, 2010 Could you provide us with an image of one letter or word that was exploded where you are encountering this type of problem? Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 20, 2010 Share Posted December 20, 2010 Does it look anything like this example of Times Roman text that I exploded? Original is on the left. Exploded text in center. Exploded text separated into its individual entities on the right. Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 20, 2010 Share Posted December 20, 2010 It seems that multiline fonts develop this effect. Times New Roman, Standard, etc. There is a LISP out there that can do this, im sure Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 20, 2010 Share Posted December 20, 2010 this was discussed in a previous post... http://www.cadtutor.net/forum/showthread.php?54694-explode-text&highlight=explode+text Quote Link to comment Share on other sites More sharing options...
SD&PC Posted December 20, 2010 Author Share Posted December 20, 2010 ok i have the file with examples savev as a .pdf how ever I am unsure how to post them. When I attempt to post an image it asks for a url.... Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 20, 2010 Share Posted December 20, 2010 Interesting program. Thanks for sharing that link JPlanera. Have you tried it out? Quote Link to comment Share on other sites More sharing options...
SD&PC Posted December 20, 2010 Author Share Posted December 20, 2010 ok I posted the file as an attachment if you zoom in on the letter "i" you will see the wierd lines I had previously mentioned. This only happens sometimes as you can see the D is fine but the N has the same issue on a smaller scale EDIT: Jplanera that is a pretty cool find however the normal extra crosses do not both the laser its the redundant lines that I posted that bothers it. Not only that it will do to many passes taking off to much and allowing light to leak from the panel which is no good. wierd fill.pdf Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 20, 2010 Share Posted December 20, 2010 Interesting program. Thanks for sharing that link JPlanera. Have you tried it out? I am actually having a hard time figuring out how to load it.... Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 20, 2010 Share Posted December 20, 2010 Scratch that. I got it... And it works beautifully! Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 20, 2010 Share Posted December 20, 2010 I am actually having a hard time figuring out how to load it.... How's it done now that you figured it out? Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 20, 2010 Share Posted December 20, 2010 How's it done now that you figured it out? My apologies. Its a .NET app so NETLOAD from the command line and navigate to the Txt2Geom\bin\Release folder and select the TextToGeom.dll file. Command: T2G to start Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 20, 2010 Share Posted December 20, 2010 Thanks JPlanera. I think that I may have seen that explanation at The Swamp but missed the significance of it. I'll have to give it a try when I get to work Tuesday. Quote Link to comment Share on other sites More sharing options...
SD&PC Posted December 21, 2010 Author Share Posted December 21, 2010 Hey guys thanks for the quick responses. I also found a quick fix less complicated but still gets the job done. After exploding the text if you get the fill line just use the normal explode command and delete all the lines inside....little bit more time consuming but it allows you to stay in one program. EDIT: O and do not forget to poly line edit the letters to join all the lines afterwards. If your doing any laser etching that is...If it is not one continuous line the laser will NOT fully etch the letters. Quote Link to comment Share on other sites More sharing options...
JPlanera Posted December 21, 2010 Share Posted December 21, 2010 Hey guys thanks for the quick responses. I also found a quick fix less complicated but still gets the job done. After exploding the text if you get the fill line just use the normal explode command and delete all the lines inside....little bit more time consuming but it allows you to stay in one program. If you really didn't want our help, you could have just said so.. Now I feel used and unappreciated. My Christmas is ruined!!! OK just kidding... Any way that fits your needs and is comfortable is always the best solution. If i may ask, did you get to load the text2geom program at all? It works right inside autocad and will be much faster than exploding and deleting lines, especially if there is a lot of them Quote Link to comment Share on other sites More sharing options...
SD&PC Posted December 21, 2010 Author Share Posted December 21, 2010 LOL:cry: sorry J....and yes I got the add on how ever I am an intern so the computer I am using might as well have a lab rat running on a wheel to power it....so the less stuff I have to run or download and save to the hard drive the better...However I did load it up on my lap top and can not wait to use it for my school work going to save me a ton of time in class. Quote Link to comment Share on other sites More sharing options...
