Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2006
    Dec 2010
    3
    Default Feet Inches to metric
    Hi,
    Does anyone have a VBA function that will convert drawing text that's in feet, inches and fractions of an inch (5'-11 -1/2") into metric equivelent? I can't seem to find one. This would be for text only, not a dimension.
    Thanks.
    Forum Deity SEANT's Avatar
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    This would work, but the text would have to be in a very specific format i.e.:
    5'-11 1/2"
    Code:
    Sub ToMetric()
    Dim entTxt As AcadText
    Dim dblmeasure As Double
    Dim varpkpt As Variant
    Dim ent As AcadEntity
       With ThisDrawing
          .Utility.GetEntity ent, varpkpt, "Select measure as text."
          If TypeOf ent Is AcadText Then
             Set entTxt = ent
             dblmeasure = .Utility.DistanceToReal(entTxt.TextString, acArchitectural) * 0.0254
             Set entTxt = ThisDrawing.ModelSpace.AddText(CStr(dblmeasure) & " Meters", entTxt.InsertionPoint, entTxt.Height)
             ent.Delete
          End If
       End With
    End Sub
    Super Member fixo's Avatar
    fixo's Computer Details
    Windows 7
    E7500
    Intel(R)Core(TM)2 DUO CPU 2.93HGz
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Thanks God, I'm far enough from Hitleropa
    1,697
    Code:
    Option Explicit
    ' --> request reference to Microsoft VBScript Regular Expression 5.5
    Sub MerryXmass()              'from fixo'
    Dim s As String
    Dim i As Long
    Dim cnt As Integer
    Dim quotes As Integer
    Dim num As Double
    Dim regex As regexp
    Set regex = New regexp
    regex.IgnoreCase = True
    regex.Global = False
    cnt = 0
    ''Tested:
    's = "5 \ ' - 11 - 1/2\ """ 'ok
    ''s = "10 - 1/2\ """ 'ok
    s = "18/32\ """ 'ok
    Dim ar() As String
    Dim decs() As String
    If quotes = 1 And cnt = 2 Then
    regex.Pattern = "(\d+)(.*)(\d{1,2})(.*)(\d+)(/)(\d{1,2})(.*)$"
    s = regex.Replace(s, "$1;$3;$5;$7")
    MsgBox s
    ar = Split(s, ";", -1, 1)
    num = (CDbl(ar(0)) * 12 + (CDbl(ar(1)) + CDbl(ar(2)) / CDbl(ar(3)))) * 0.0254
    ElseIf quotes = 0 And cnt = 1 Then
    s = Replace(s, "-", ";", 1, -1, 1)
    s = Replace(s, Chr(34), "", 1, -1, 0)
    s = Replace(s, Chr(92), "", 1, -1, 0)
    ar = Split(s, ";", -1, 0)
    decs = Split(ar(1), "/", -1, 0)
    num = (CDbl(ar(0) + CDbl(decs(0)) / CDbl(decs(1)))) * 0.0254
    ElseIf quotes = 0 And cnt = 0 Then
    s = Replace(s, "/", ";", 1, -1, 1)
    decs = Split(s, ";", -1, 0)
    num = (CDbl(decs(0)) / CDbl(decs(1))) * 0.0254
    Else
    MsgBox "Unknown format"
    End If ''
    Set regex = Nothing
    Debug.Print num
    End Sub
    Private Function CountChars(source As String, find As String) As Integer
    Dim i As Long
    Dim c As Long
    Dim ch As Integer
    ch = Asc(find)
    Dim x() As Byte
    x = StrConv(source, vbFromUnicode)
    For i = 0 To UBound(x)
    If x(i) = CByte(ch) Then
    c = c + 1
    End If
    Next
    CountChars = c
    End Function
    Merry Xmass *Seant* and all of the friends of mine from here
    Oleg
    The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
    Forum Newbie
    AutoCAD 2006
    Dec 2010
    3
    MerryXmas Fixo but I'm stuck on how to use MerryXmass. I'm almost certain it's what I'm looking for. What would you recommend I try to see how this will work with some AutoCAD text?
  5. #5
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    1,697
    I didn't check the project carefully, you make it
  6. #6
    AutoCAD 2014
    Aug 2005
    Rhode Island
    2,463
    Merry Christmas, Fixo, my friend. I’ll have to study this use of Regular Expression; a nice gift for anyone, not just the original poster.
  7. #7
    Windows 7
    E7500
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    1,697
    Thanks so much , Sean, my friend
    Unfortunatelly, I have not enough time to write all condition using regular expression
    just the first one from them
    I'd like to wish you all of the best in new year
    Regards,
    Oleg
  8. #8
    Forum Newbie
    AutoCAD 2006
    Dec 2010
    3
    FaLaLaLaLa...LaLaLaLa.
    Thank you Fixo! Having much fun with your gift. Still tweeking it but had to let you know I'm thrilled so far.
  1. change ordi.lsp to feet and inches from decimal inches?
    By losquest in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Sep 2010, 11:43 pm
  2. feet inches to metric
    By Nathandi in forum AutoCAD Beginners' Area
    Last Post: 22nd Dec 2009, 12:32 pm
  3. how to set feet & inches
    By gracehazelby in forum AutoCAD General
    Last Post: 23rd Oct 2008, 05:06 pm
  4. Convert Feet & Inches Drawing into Metric??
    By Unick in forum AutoCAD Drawing Management & Output
    Last Post: 1st Aug 2007, 03:39 pm
  5. inches to feet
    By giloosh in forum AutoCAD Beginners' Area
    Last Post: 13th Sep 2005, 10:49 pm
