Results 1 to 2 of 2
    Full Member
    AutoCAD 2011
    Mar 2010
    38
    Default Annotative block issue
    I have attached an annotative block. I have a problem when trying to drag the annotative view to a different area on the plan to prevent overlap on larger scales. I have an alignment grip at the base point. when i try to drag the 1/8 scale view for example;the entire block moves. I have moved the basepoint to make this work and it does but I cant have the basepoint and the alignment parameters at the same location as it always moves all views of the block
    Senior Member edwinprakoso's Avatar
    edwinprakoso's Computer Details
    Windows 10 Professional
    Sony Vaio T11
    6 GB
    Intel HD4000
    AutoCAD 2017
    Nov 2009
    Jakarta, Indonesia
    345
    That's the downside if you place the alignment at base point.
    How do you use the block? If you only need the alignment for placement, then you can consider to create nested block:
    1. delete the alignment in current block
    2. create the existing block (rec) as another block.
    3. add the alignment parameter in parent block.
    4. You can now place it to your drawing, then explode after you finish. Or you can activate explode during placement.
    Another way is you add alignment parameter at other location. This will not align block during placement, you need to move it using align grip after placing it.
    Edwin Prakoso | www.cad-notes.com
    The work doesn't matter if it's not built
  1. make a block annotative
    By cadmench in forum AutoCAD General
    Last Post: 12th Jan 2012, 08:44 pm
  2. Insert annotative block as non annotative dwg + trim object scalelist
    By Fnuik in forum AutoLISP, Visual LISP & DCL
    Last Post: 6th Dec 2010, 09:14 pm
  3. creating annotative block
    By dundeeslugger in forum AutoCAD Beginners' Area
    Last Post: 8th Jun 2009, 09:36 pm
  4. Annotative block does not display
    By kenny in forum AutoCAD Beginners' Area
    Last Post: 30th Apr 2009, 02:00 pm
  5. Flagging a block as annotative
    By CADperson in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Feb 2009, 07:33 pm
