Results 1 to 4 of 4
    Forum Newbie
    AutoCAD 2010
    Dec 2010
    1
    Idea low memory problem in AutoCAD 2010
    I have problem working with Autocad 2010. There is freequently meassage open that " AutoCAd working out of memory and some occuring fatal error and then shut down autocad." My machine configeration Windows vista, 3.2 windows experience index, Intel(R) Core(TM) 2 Duo CPU E8400 @ 3.00GHz 3.00 GHz, 4.00 GB RAM, 32-bit Operating System. But when I am working in AutoCAD 2008 there is no face such type of problems.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    What type of drawing are you working with when the error occurs? 2D or 3D?
    You indicate that your 32-bit system has 4GB of RAM installed. Do you have the 3GB Switch enabled in your Boot.ini file?
    Sometimes an "out of memory" error message is the result of an undersized swap file also referred to as virtual memory. Have you been tinkering with your virtual memory settings?
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell OptiPlex 7020
    i7 4790 3.6GHz
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    AMD Radeon 2GB
    Samsung 480Gb SSD
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2017
    Nov 2007
    4,590
    http://usa.autodesk.com/adsk/servlet...linkID=9240617
    Always try the autodesk knowledge base for answers.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
    Full Member Slaraffenmann's Avatar
    Slaraffenmann's Computer Details
    win 7
    Quadro FX1700
    Map 3D 2011
    Aug 2010
    Norway
    46
    Go to autodesks servicecenter and make sure you have installed the last updates.
    I did also have this problem when I installed 2010. But after doing som updates things started to run much smoother.
  1. MAX10 memory problem
    By 3darchi in forum Cameras, Lighting & Rendering
    Last Post: 11th Nov 2010, 02:50 pm
  2. AutoCAD 2010 out of memory in spite of /3GB switch
    By Cadfisch in forum AutoCAD General
    Last Post: 15th Oct 2010, 05:59 am
  3. AutoCAD 2010 Viewport Problem
    By and5e in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Jul 2010, 12:41 pm
  4. Autocad 2010 OSNAPCOORD problem
    By CadKid in forum AutoCAD General
    Last Post: 28th Jan 2010, 06:42 pm
  5. AutoCad 2009 Memory/Render problem
    By Cadfisch in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Jun 2009, 11:12 pm
