Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    Senior Member Hardney's Avatar
    Civil 3D 2013
    Dec 2005
    Montreal, Qc
    172
    Default Blinking crosshairs
    Hi,
    One of my co-worker has this problem with his cursor's crosshairs. When he moves his cursor the crosshairs are like blinking or sort of flashing. It's not that big of a problem but it's just getting anoying in a short while. Have any idea how to fix that problem?
    Thank You
    Senior Member Dommy2Hotty's Avatar
    AutoCAD 2007
    Mar 2004
    Homer Glen, IL
    350
    Tool palettes with transparency turned on, I'm assuming...
    AutoCAD 2005
    ADT 2005
    Civil 3D 2013
    Dec 2005
    Montreal, Qc
    172
    Hmm,
    not sure, because it hasn't to do with the menu palette, it is only the cursor that kind of appear and disapear when moving it...
    Civil 3D 2013
    Dec 2005
    Montreal, Qc
    172
    Default Precision
    One of my other co-workers was just wondering if it could be caused by a Windows Update, because our computer technician just made one yesterday evening and those who had the update have this problem now. Could there be a link between the two things?
  5. #5
    AutoCAD 2007
    Mar 2004
    Homer Glen, IL
    350
    Couldn't confirm that.
    When I turn transparency on for the tool palettes, my video card (at home) can't handle it, so it makes the crosshair turn on and off as it's moved. That's my idea on what is causing it.
    AutoCAD 2005
    ADT 2005
  6. #6
    Civil 3D 2013
    Dec 2005
    Montreal, Qc
    172
    So now I should turn it off with typing paletteopaque then 2 if I am not wrong. Could you confirm that to me, I'm just not familiar with that function and by the way if you don't mind, could you explain to me what the transparency function is used for?
    Thank You
  7. #7
    AutoCAD 2007
    Mar 2004
    Homer Glen, IL
    350
    AutoCAD 2005
    ADT 2005
  8. #8
    Forum Newbie
    AutoCAD 2012
    Aug 2011
    3
    A little late but I had the same issue on AutoCAD 2012. So here is what I did to solve the issue. I'm writing this, so if someone has the same issue this may guide to solve. Anyway here is my solution;
    If you have a blinking issue on AutoCAD, check Hardware Accelerator (HA) if it's turned on of off. When I turned HA my blinking issue is gone...
  9. #9
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,099
    Quote Originally Posted by Funerall View Post
    That is not a solution, just a workaround. Did you turn Hardware acceleration ON or OFF?
    The solution is to get an up to date approved driver from Autodesk site or get a new certified graphics card. If you have an onboard graphics more RAM might help.
    What graphics card do you have?
  10. #10
    Super Member DANIEL's Avatar
    Mechanical
    DANIEL's Discipline Details
    Industrial
    Mechanical
    AutoCAD 2012
    May 2005
    Arlington Texas
    995
    you need a better graphics card and or more RAM I can almost garantee you, as I have seen others experience this over the years with various versions of AutoCAD.
    If you would like to help my 2 year old niece Alaina in her battle against Leukemia you can donate blood at any Carter Blood Care and put SPON050875 on the donor form. Thank you so much for any contributions in this matter that you can make.
    Luminous beings are we, not this crude matter.
