Results 1 to 6 of 6
Thread: DIMLFAC routine
    Senior Member jmerch's Avatar
    MEP 2010
    Sep 2010
    186
    Default DIMLFAC routine
    Trying to get the following snippet of code to work. If I do each line singly it works but when it's in my LISP as the following, it does not set the DIMLFAC. Any reason why? I had some guidance on the defun round function but the rest of the code I can't get to work.
    Code:
    (defun round (value to)
      (setq to (abs to))
      (* to (fix (/ ((if (minusp value) - +) value (* to 0.5)) to)))
    (setq dimlfac (getvar "dimlfac"))
      (setq value (vla-get-customscale(vla-get-activepviewport(vla-get-activedocument(vlax-get-acad-object)))))
      (setq vpscale (/ 1 value))
      (setvar "dimlfac" vpscale)
      (dimvalue)
      (command "pspace")
      (command "_dimlinear" pause pause pause)
      (command "dimcontinue")
      (setvar "dimlfac" dimlfac)
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,972
    Code:
      (dimvalue)
      (command "pspace")
      (command "dimcontinue")\
    (while (> (getvar 'cmdactive) 0)
    (command pause))
    And as much as possible, avoid using variable names the same as a function/system/native symbol names
    Senior Member
    AutoCAD 2010
    Jul 2010
    370
    I guess that the problem were with the extra parens .
    Code:
     (* to (fix (/
              value
              (* to 0.5)) to))
    Regards
    MEP 2010
    Sep 2010
    186
    @pBe: the added code still didn't work and doesn't set the dimlfac. I am curious though on the "while" function. My original question in this thread was going to be about "while" b/c I had it in there but didn't understand it fully. I can't find any tutorials on the while/cmdactive and would like to understand how it works.
    @Michaels: I took out the extra parens but it still didn't seem to work either.
    I do appreciate your help.
  5. #5
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    2,972
    thats odd, it works fine with mine
    what is the sub (dimvalue) do anyway?
  6. #6
    MEP 2010
    Sep 2010
    186
    (dimvalue) was my bad . I tried taking the first couple lines out of that function and put into a separate one to be called up in my main one to see if that worked. I forgot to erase it when I scrapped that idea and posted my code. So I deleted that. I restarted my computer just to clear it up and see if the lisp worked now. It does work now, BUT it's still not setting the DIMLFAC. If i exclude the last line to reset the DIMLFAC, then run the script, the DIMLFAC should be 96 (based on my 1/8" viewport). It's not, it still reads 1 BUT the dimensions come out right...how is that? The dims come out as if the DIMLFAC is actually 96.
    and to touch on this, I do try to avoid using those names but I'm not 100% familiar with ALL the names so sometimes here and there I may accidentally use one I shouldn't. I think from here on out I may just add a digit after the name to be sure it's not a system name.
  1. DIMLFAC Message Alert Box Creation
    By balajibth84 in forum AutoLISP, Visual LISP & DCL
    Last Post: 23rd Oct 2010, 05:34 pm
  2. dwg to xls routine?
    By edgar_hj1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2010, 03:28 pm
  3. Help with this routine
    By jcap91163 in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Aug 2010, 01:28 pm
  4. Just another routine, pls take a look
    By pryzmm in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jul 2007, 04:04 pm
  5. DIMLFAC?
    By besolid in forum AutoCAD Beginners' Area
    Last Post: 6th Mar 2006, 11:31 am
