Results 1 to 5 of 5
    Senior Member
    AutoCAD 2008
    Dec 2007
    130
    Default Change current layer and selection set to layer 0..
    Hi All,
    I want a quick LISP command to change the current layer to 0 but not just do that, i want to be able to select objects first to change, so it changes all selected objects and the drawing's current layer to 0. I've tried this code out but it won't work (not the changing slected objects bit anyway)....any ideas on what i'm doing wrong or a better solution to my code?
    Code:
    ; SET OBJECTS AND CURRENT LAYER TO 0..
    (defun C:00 ()
      (setq a (cadr (ssgetfirst)))
      (if a (command "-LAYER" "S" " " a "S" "0" ""))
    Thanks,
    Cheers,
    PaulRenegade @ hardwiredstudios..
    XP Pro / AutoCAD 2007 : Pentium Core 2 Q6600 Quad Core : ASUS P5N-E SLI Motherboard : 4GB DDR2 RAM : 2 x SLI NVIDIA 8500GT SLi 1024MB DDR2 PCI-Express Graphics Cards
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,115
    oops.. wrong thread
    anyhoo...
    Edit: I was called away when i was about to reply to another thread but somebody mess with my station.. serves me right not locking my desktop
    Super Member David Bethel's Avatar
    Multi-disciplinary
    David Bethel's Discipline Details
    Multi-disciplinary
    Commercial Food Service
    AutoCAD pre 2000
    Dec 2003
    Newport News, Virginia
    1,926
    maybe:
    Code:
    (defun c:oo (/ ss)
      (while (not ss)
             (princ "\nSelect Entites To Change To Layer 0")
             (setq ss (ssget)))
      (command "_.LAYER" "_UNlock" "0" "_Thaw" "0" "_ON" "0" "_Set" "0" ""
               "_.CHPROP" ss "" "_LA" "0" "")
      (prin1))
    I wouldn't recommend using numeric characters ( if that is what they are ) as the leading character or all characters in a function name. I couldn't tell if they were zeros or the letter O. -David
    R12 (Dos) - A2K
    Super Member irneb's Avatar
    irneb's Computer Details
    Win7 Pro 64bit
    Antec One Hundred
    ASUS P8P67-Pro P67
    Intel i7 2600 @ 3.4GHz
    16GB-1600MHz
    GeForce GT 430 (1GB)
    Seagate1TB SATA2 - 7200rpm
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Architectural
    irneb's Discipline Details
    Architectural Technician and Programmer
    Architectural
    AutoCAD 2013
    Sep 2010
    Jo'burg SA
    1,635
    Or if you want to use the pre-selection:
    Code:
    (defun C:00 (/ a)
      (if (setq a (cadr (ssgetfirst)))
        (command "_.change" a "" "_Properties" "_LAyer" "0" "")
      (command "_.LAYER" "_Set" "0" "")
    Senior Member
    VVA's Computer Details
    Windows 7
    Intel Core i5-2400
    8 Gb
    Nvidia Quadro 600
    Seagate 500 GB + WD 750 GB
    Philips 27"
    AutoCAD 2013
    Dec 2006
    Minsk, Belarus
    401
    #3 + #4 = #5
    Code:
    (defun C:00 ( / ss)
      (if (or (setq ss (cadr (ssgetfirst)))
              (and (princ "\nSelect Entites To Change To Layer 0")
                   (setq ss (ssget "_:L"))
  1. Replies: 2
    Last Post: 15th Oct 2009, 11:10 am
  2. current layer change
    By hokie555 in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Oct 2009, 09:40 pm
  3. By layer objects - change layer but keep colour?
    By Connect Project Tech in forum AutoCAD General
    Last Post: 9th Jan 2009, 05:49 pm
  4. Change Layer Prefixs and Layer Names
    By ML0940 in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jul 2008, 11:11 am
  5. Change layer and return to layer using button
    By Vigilante in forum AutoCAD General
    Last Post: 6th Sep 2007, 07:01 pm
