Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
  1. #21
    Super Member kencaz's Avatar
    kencaz's Computer Details
    XP Pro, Vista, Linux,W7
    HP,s Dell
    Mechanical
    kencaz's Discipline Details
    Designer/Machinist
    Mechanical
    AutoCAD 2013
    Jul 2007
    Las Vegas, NV
    759
    Quote Originally Posted by Firligic View Post
    this is for the structural drawing, I dont want my dimensions to be all wrong before I send it in for grading
    and how do I use reference option.
    once I use command scale, all it ask me to do is select base point.
    Some of my AutoCAD and Inventor Pics and Videos...
    http://www.youtube.com/kencaz45
  2. #22
    Super Member Ryder76's Avatar
    Ryder76's Computer Details
    Windows 7
    Dell T7500
    See details...
    Ryder76's Discipline Details
    Electrical Designer - Oil & Gas
    See details below.
    Subsea Solutions
    AutoCAD 2010
    May 2009
    Houston, Texas
    570
    Command: _scale
    Select objects: select the object(s) you want to scale
    hit enter
    Specify base point: select the point you want to scale from
    Specify scale factor or [Copy/Reference] <1.0000>: r
    Specify reference length <1.0000>: this is the length of the known object you - if you know the length type that in if not then select the first point then...
    Specify second point: select the second point
    Specify new length or [Points] <1.0000>: here you can type in the length you want it to be if you know it or select the 'third' point you want to scale to.
    This works scaling up or down. It can be a bit tricky until you try it a few times, but once you get the hang of it you will love this command.
    "Great spirits have always encountered violent opposition from mediocre minds." - Albert Einstein
  3. #23
    Full Member
    AutoCAD 2010
    Dec 2010
    45
    thank you guys.
    I think i need to purchase a t-shirt saying I <3 CADTUTOR
  4. #24
    Full Member
    AutoCAD 2010
    Dec 2010
    45
    yup just did all those steps. everything is back to normal, dimensions is correct thank you guys. ill never do this same mistake again
  5. #25
    Junior Member
    armydude2211's Computer Details
    ASUS Notebook U50A
    Intel(R) Core(TM)2 Duo CPU T6600 @ 2.20 GHZ
    4gb
    I broke my laptop monitor so I borrowed a old ViewSonic.
    AutoCAD 2010
    Dec 2010
    Ft. Lewis, Washington
    14
    ok I have been trying to follow all of these threads. I am having about the same problem. I drew out the structural project for penn foster 1:1 on the model space then put on my dimensions and placed a premade titleblock on but i could not get any of the scales to change. after nothing worked I used "scale" to get the title block to the right size. then after reading what was put on here i deleted it all and started over. Will someone please help me out. I got behind redeploying back from Iraq and am kind of running short on time. I will post what i have so far if someone could take a look at it for me please. Thank you.
  6. #26
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I took a quick look. On Layout 1 your viewport is set to 1/64"=1'. Is that because you plan on printing it out on a 8.5x11 sheet of paper? What do your instructions say about the sheet size that should be used?
    One other thing I noticed. When you saved the drawing all of your viewports, in each of your three layouts, were activated (as though you were working in model space) and none of them were locked. This means you could inadvertently change the scale of a viewport without knowing it.
    Question: What are the center-to-center dimensions supposed to be both horizontally and vertically on your columns?
    Question: Why are your columns (W12x152), which look to all be the same, not a block? Creating a W-shape out of individual lines is not a good practice. If you are going to do it this way turn it into a block to make it more efficient and remember to create blocks on Layer 0 so that when they are inserted on a particular layer they take on all the properties of that layer like color and linetype. Didn't they cover this is one of the projects/assignments?
  7. #27
    Junior Member
    ASUS Notebook U50A
    4gb
    AutoCAD 2010
    Dec 2010
    14
    sorry it took me so long to respond ReMark. Thank you for taking a look at it for me. No, the drawing is going to be printed on 11 X 17. The center to center between all of the W12 X 152 is 18'. I did not even think about making the colums into blocks I just drew them up real quick and put them on by array real quick. I do not know what I am doing wrong on this drawing so I keep starting over with it. So I have got pretty quick on putting the girders and the channels in.
    Yes they did go over blocks in one of the chapters, but it was just in a written test, not in a drawing. Here is another attempt that i started over with and was actually able to get the dimentions in but they are huge and I dont get it. I really really need practice in structural. I did well in the plat drawing but this structure is beating me up lol.
  8. #28
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    As Remark said, I would use blocks for the I beams and also make sure you look the viewport (once you have it set correctly). I personally would have done the drawing in model space at 1:1 as you did, set up a viewport in paperspace at my desired scale and then added my dimensions, text, notes (including the title block obviously) in paperspace and not use annotative scaling.
  9. #29
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I'm not sure where to begin.
    I opened your drawing this morning (2/15) and find I am in a paper space layout and the viewport is "active" and the display is not locked. Neither of these conditions are good AutoCAD practices in my opinion.
    Your viewport is on layer W12x152. It should be on its own layer (ex. - Vports) and set to "no print" in the Layer Properties Manager.
    When I invoke the Plot command the page size is still listed as 8.5x11 and not 11x17.
    You have a layer called Center-Bubble with a linetype of Center assigned. In my opinion the bubble should be drawn using a continuous linetype otherwise it doesn't look right in your layout (the circle is broken up and not continuous).
    Your title block and border are in model space when they should really be in your layout and they should be on their own layer (ex. - TB&B) not on the "dimentions" layer.
    What scale had you planned on assigning to your viewport? Although you have your annotation scale set for 3/32"=1'-0" there is no scale assigned to the viewport itself.
    In my opinion the girders should have been drawn as a single continuous polyline and not as separate lines. Some girders are missing a line.
    In my opinion the columns should be a block or at the very least a single continuous polyline.
    Re: annotation scaling. Your text height is rather large. When I check "Properties" I see you have an annotative scale set of 3/32"=1'-0" but a Paper space text height of 13/64" is listed. Keeping in mind that 1/8" high text is fairly normal in these types of drawings 13/64" is really too big.
    Layers named Border, Border2 and Hidden seem to have no objects on them.
    There is no need for the three layers Text Large, Text Medium and Text Small. Have one layer for Text and that's it.
    The layer name dimentions should be dimensions.
    In Layout 2 you have a title block and border sitting way off to the right. The block name is "new block" and you have it inserted on layer "C9 x 20". This is wrong in so many ways.
    Your "new block" block (title block and border on layout 2) is 10x16. I don't know if your were planning to use an ANSI B (11.00x17.00) page layout but if you were, your border would be about 1/2" too wide. AutoCAD says anything within the dashed lines you see (the "hard clip" areas) will be printed. Anything outside of those lines will be cut off. Either adjust your title block and border (make it 15" instead of 16" wide) or find another 11x17 format that gives you the extra room you need to fit it within the dashed lines. This will be dependent upon the printer you'll be using. Different printers/plotters will offer different options.
    If you were to do a new page setup using a 11x17 sheet size I think you could set your viewport scale to 1/8"=1'-0" which is fairly common amongst structural and architectural firms (along with 1/4"=1'-0"). Just a suggestion.
    I'm sure there is more but I only took a quick look.
  10. #30
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Sorry I missed this one. I did use block at first either, you should. Penn foster frowns on the use of view ports ( I do not know why) they want every thing set up to plot from model space. Be very carefull with the elevations.
  1. Problem with scaling
    By alan_mardan in forum AutoCAD Beginners' Area
    Last Post: 12th Nov 2010, 05:23 pm
  2. Scaling problem
    By Ricardo in forum AutoCAD Beginners' Area
    Last Post: 22nd Feb 2010, 05:31 am
  3. Scaling Problem
    By boiler6700 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Nov 2008, 06:30 pm
  4. scaling problem
    By njgomez in forum AutoCAD Beginners' Area
    Last Post: 4th Jan 2008, 02:33 pm
  5. problem scaling (dims)
    By megapod in forum AutoCAD Drawing Management & Output
    Last Post: 10th Feb 2006, 09:47 am
