How to select the blocks only in current space (either model or paper space)
muthu123
Dear friends,
If i used "all" in ssget fucntion as follows, it will return all the blocks including model space and paper space. But how can i use the filter to select only in current active space.
 (Setq ss (ssget "all"
               (list (cons 0 "INSERT") (cons 2 "A1_TITLE_BLOCK") (cons 66 1))
We have found the way to solve that by following code
               (list (cons 0 "INSERT") (cons 2 "A1_TITLE_BLOCK") (cons 66 1) (cons 410 (getvar "ctab")))
Here it is ...... :)
(Setq ss (ssget "_x"
Michaels
  • 7 months later...
Hi all
Ran across this post looking for "how to select all object in current layout"
What does the (cons 66 1) do?
I found the DXF code in help menu under "Group Code in Numerical Order"
(Group Code 66 "Entities follow" flag (fixed)) I am not sure what this means and where did the 1 come from.
Thanks
Hi all
only selects blocks with attributes.
Thanks
I guess my process should have been: Look to see what is being selected (cons 0 "INSERT")
then I should have gone to INSERT and looked at the DXF codes there to find my answer.
Sometimes I have the hardest time finding my way around
Another question since I am here:
The OP use (cons 410) to get string for (getvar "ctab")
This 410 is not part of the "insert" DXF code that I can see, why use 410? I also see 410-419, 430-439 and 470-479
What is the difference and how would I know to use which one?
Try:
(cons 410
      (if (eq 1 (getvar 'CVPORT))
        (getvar 'CTAB)
        "Model"
... Why not just:
(cons 410 (getvar 'ctab))
Developer Help >> DXF Reference >> ENTITIES >> Common Group Codes for Entities >> DXF code 410
Guest kruuger
... Why not just:
because then we got incorrect info about layout when we in "model" but thru viewport
k.
EDIT: i'm to slow :)
