Results 1 to 6 of 6
    Junior Member
    Timothyl's Computer Details
    Windows XP
    AutoCAD LT 2011
    Jan 2011
    24
    Default Importing images into AutoCad
    Hi all,
    I'm new to the forum and excited to find it. I'm also fairly new to AutoCAD (running AutoCADLT2011). I'm doing a drawing of a front door system which will have antique stained glass in it. I want to present the drawing with some semblance of how the glass will look in it. Is there a way I can import an image of the stained glass- even to just "trace" over it?
    Tim
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,205
    While I don't use LT, I did a little digging and found out that it does let you put images into drawings. One way is as an external reference, the other is as an OLE object. Both methods give you a link to the image file, they don't actually import it. If you have an Insert menu/button, there should be options for both.
    Welcome to the forum!
    breaking AutoCAD on a regular basis since 1991
    Junior Member
    Windows XP
    AutoCAD LT 2011
    Jan 2011
    24
    I'll do some experimenting with that. After I made my post I decided to just try cutting and pasting a jpeg into a autoCAD drawing and was surprised that it worked- even though it came in as a huge image compared to the drawing. I'm not sure if that's the optimal way to do it. Thanks so much for the input!
    Tim
    Forum Newbie
    Revit 9
    Jan 2011
    7
    First create a jpeg of just the glass so that the edge of the image is the edge of the glass in the door. Then on the autocad command line type image. Click attach then address the jpeg. remember to save the path! you can scale, copy, drag, move, rotate, mirror and cut this object by clicking on its extreme edges to select it. Use draw order to place it behind the rest of your cad drawing.
    Good luck
    Premph
  5. #5
    Junior Member
    Windows XP
    AutoCAD LT 2011
    Jan 2011
    24
    Premph- thanks so much. That works great!
  6. #6
    Senior Member ccowgill's Avatar
    ccowgill's Computer Details
    Windows 10
    Sabretooth
    AMD
    32GB
    AMD R9 390
    SSD
    Triple Monitor system
    Civil
    ccowgill's Discipline Details
    Civil Engineer
    Civil
    Licensed Civil Engineer in Michigan, Indiana, and Ohio
    Civil 3D 2017
    Dec 2010
    Hartford, Michigan
    205
    I'd recommend attaching it, I think that attached images are much easier to work with than OLE objects, but that's just my opinion.
    Christopher T. Cowgill, P.E.
    AEC Industry Collection 2018 on Windows 10
  1. importing images crashes acad
    By randomnewb in forum AutoCAD General
    Last Post: 2nd Oct 2009, 12:00 pm
  2. help importing images into autocad 2010 mech.
    By matulja87 in forum AutoCAD General
    Last Post: 12th May 2009, 07:27 pm
  3. Importing Images
    By tbylan1 in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Apr 2008, 04:38 pm
  4. importing raster images cad lt 2008 ??
    By STU in forum AutoCAD Drawing Management & Output
    Last Post: 21st May 2007, 11:13 am
  5. Importing images
    By Luchini in forum AutoCAD General
    Last Post: 12th Apr 2006, 02:21 am
