+ Reply to Thread
Results 1 to 7 of 7
  1. #1
    Junior Member
    Using
    not specified
    Join Date
    Jan 2006
    Posts
    16
    Default problem with UCS when changing views
    Why does the current UCS change whenever I switch between views? (front,back,top,etc.)
    I'm using Autocad 2004.
  2. #2
    Forum Deity
    Using
    not specified
    Join Date
    Jul 2004
    Location
    Anchorage, Alaska
    Posts
    2,074
    Default
    Not sure what you're experiencing, but you can alter that by changing your UCSFOLLOW setting.
  3. #3
    Super Member
    Using
    Architecture 2010
    Join Date
    Jan 2006
    Location
    canada, eh!
    Posts
    607
    Default
    it switches because those "views" are UCS's that you're changing to...
  4. #4
    Junior Member
    Using
    not specified
    Join Date
    Jan 2006
    Posts
    16
    Default
    thanks for the info, guys. By the way, what exactly does the UCSFOLLOW command do?
  5. #5
    Forum Newbie
    Using
    not specified
    Join Date
    Nov 2005
    Location
    Norway
    Posts
    6
    Default
    This is something i have had to deal with for a long time , i am using ADT 2006 .Wen changing views and maby a dash of 3D orbit my UCS always gets fu**ked . Type ucs <enter> w for world and <enter> again.
    This works for me , i had the same problem in ADT 2007 DEMO by the way.
  6. #6
    Junior Member Hammeroid's Avatar
    Using
    AutoCAD 2007
    Join Date
    Nov 2005
    Location
    London
    Posts
    12
    Default ucsfollow
    Straight out the help file:
    The UCSFOLLOW setting is saved separately for each viewport. If UCSFOLLOW is on for a particular viewport, a plan view is generated in that viewport whenever you change coordinate systems. Once the new UCS has been established, you can use DVIEW, PLAN, VIEW, or VPOINT to change the view of the drawing. It will change to a plan view again the next time you change coordinate systems.
    0 UCS does not affect the view
    1 Any UCS change causes a change to the plan view of the new UCS in the current viewport
    The setting of UCSFOLLOW is maintained separately for paper space and model space and can be accessed in either, but the setting is ignored while in paper space (it is always treated as if set to 0). Although you can define a non-world UCS in paper space, the view remains in plan view to the world coordinate system
  7. #7
    Forum Newbie
    Using
    AutoCAD 2011
    Join Date
    Feb 2012
    Posts
    2
    Default
    set UCSORTHO to 1 and it will allow your UCS to follow typical views. (top, front, side, ect.) Meaning it will remain xy in every view.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
