AutoCAD LT Error Aborting
djkevo
Aloha,
I received a DWG from a client and need to add field mark-ups. I completed the additions and tried to save and get 'FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 6237788h' It tries to recover file but in unsuccessfull. Other files from the same client work fine.
They use AUTOCad 2006 and I'm using AUTOCad 2008 LT. I hope there can be a solution for this problem.
Thank you,
djkevo
