Results 1 to 9 of 9
    Senior Member
    AutoCAD 2011
    Sep 2009
    Austria / Europe
    196
    Default Rotate around x,y,z-axis
    Hi,
    does anybody have a (presumably short) piece of code doing the following:
    Code:
    Command: rx (rotate aoround x-axis)
    does: rotate3d with x-axis pre-chosen as rotation axis
    and
    ry, rz
    Thanx!
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,501
    vla-Rotate3D function?
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Senior Member
    AutoCAD 2011
    Sep 2009
    Austria / Europe
    196
    Sorry Lee Mac, I don't get the point in vla-rotation.
    I'm talking about rotation around the 3 main axis.
    rx shall rotate around x-axis, ry around the y-axis, rz ...
    You just choose 1 point to rotate around.
    It's just about sparing 1 option in the rotate3d command.
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,501
    Quote Originally Posted by Randolph View Post
    I know you are, which is why I suggested vla-Rotate3D
    Code:
    (vla-rotate3D <object> <point1> <point2> <angle>)
    Where <point1> and <point2> are the two points defining your axis of rotation.
  5. #5
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,406
    I think you should look at the command version first "Rotate3d" understand how that works and then re-read Lee's answer particuarly using points rather than X Y Z
    0,0,0 1,0,0 is a direction in the x axis but you need a point on your object to start.
  6. #6
    Senior Member
    AutoCAD 2011
    Sep 2009
    Austria / Europe
    196
    I feel like I'm writing chinese
    Bigal, I really do know my Euclides.
    Let's try it with german AutoCAD
    Code:
    Befehl: r3
    _ROTATE3D
    Aktueller positiver Winkel: ANGDIR=Gegen den Uhrzeigersinn  ANGBASE=0.00
    Objekte wählen: nil
    Objekte wählen: 1 gefunden
    Objekte wählen:
    Ersten Punkt auf Achse angeben oder Achse definieren nach
    [Objekt/Letztes/ANsicht/X-achse/Y-achse/Z-achse/2Punkte]: *Abbruch*
    This is:
    Code:
    r3 = rotate 3d
    select objects
    choose point on axis or define axis by
    [... X-axis/Y-axis/Z-axis ...]
    And this what I want to spare - just a simple rotate 3d with X-axis preselected ... and one with Y-axis preselected and one with Z-axis preselected.
    Should work like this:
    Code:
    rx
    select objects
    define rotation base point
    objects are rotated around x-parallel through base point.
    It's really something very simple. I JUST want to spare the one step of entering "x" in the rotat3d command. For the lisp-pros this should be something extremely simplistic ...
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,501
    Ok, I'll give you a little help:
    Code:
    (defun c:rx ( / e p a )
      (if
        (and
          (setq e (car (entsel)))
          (setq p (getpoint "\nBase Point: "))
          (setq a (getangle p "\nAngle: "))
        (vla-Rotate3D
          (vlax-ename->vla-object e)
          (vlax-3D-point (trans p 1 0))
          (vlax-3D-point (mapcar '+ (trans p 1 0) '(1. 0. 0.)))
          a
    That's one way to do it.
    Note that if you want to rotate a selection set, you wil need to iterate through it, rotating each object in turn. Also note that the above will rotate about the WCS X-Axis, not the UCS X-Axis.
    Lee
  8. #8
    Senior Member
    AutoCAD 2011
    Sep 2009
    Austria / Europe
    196
    Thanx, I'll try this. May I ask you what your reason is for preferring vla-rotate3d to rotate3d?
    I know how to preselect an option which appear 1st instance like:
    (DEFUN C:BX ()(COMMAND "_UCS" "X"))
    whereas
    (DEFUN C:RX ()(COMMAND "_ROTATE3D" "_X"))
    doesn't work: wrong selection, point required.
    So I tried to figure out how to preselect options which appear only 2nd or 3d row when working through a command.
    BECAUSE next thing would be mx, my, mz:
    MX mirror3d on YZ-parallel plane
    MY mirror3d on ZX-parallel plane
  9. #9
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,406
    The first thing rotate3d does is asks for object to be rotated! You cant jump 2 steps ahead and then go back.
    Lee has posted the answer you just change the reference in (vlax-3D-point (mapcar '+ (trans p 1 0) '(1. 0. 0.))) for the y axis '(0. 1. 0.) he even called it "rx" once loaded automaticaly at start up it doesn't matter how much code is involved. You just type rx.
  1. Rotate in 3D (Z Axis)
    By Primal Scientist in forum AutoCAD General
    Last Post: 25th Nov 2009, 11:46 am
  2. Unable to rotate around Y axis with RMB
    By deangelis in forum Rhino
    Last Post: 1st Jan 2008, 07:10 am
  3. Error: The UCS X axis and Y axis must be perpendicular
    By Gerardus in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Jan 2006, 01:02 am
  4. isolating an object to rotate on 3d axis
    By ethrim in forum AutoCAD Beginners' Area
    Last Post: 1st Nov 2005, 05:08 pm
  5. Rotate with Multiple Axis? 2D
    By fewer_98 in forum AutoCAD Drawing Management & Output
    Last Post: 10th Nov 2004, 08:56 pm
