Results 1 to 7 of 7
Thread: Trimming pipes
    Forum Newbie
    Inventor 2010
    Jan 2011
    4
    Default Trimming pipes
    hi,
    I've got a small problem; on the attached jpeg you will see a housing (shown in black) and a pipe inserted from underneath.
    how can i trim the material (of the inserted pipe) so that its flush with the hole in the bottom of the housing i.e. so nono is visible when looking through the housing)?
    somebody please help!
    Thanks
    Ben
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    I'm not familiar with trimming in jpegs - zip and attach you assembly here.
    Forum Newbie
    Inventor 2010
    Jan 2011
    4
    i use Inventor 2010.
    i've tried to attach the zip file, but its too large.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by bengee54 View Post
    Roll up the part EOPs first.
  5. #5
    Senior Member
    AutoCAD 2011
    Jan 2012
    238
    I know its an old post , but does anyone found a way to solve this ?
    Thanks
  6. #6
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    I dont use inventor but it should be the same as in Autocad just some suggestions
    1 subtract an amount from the pipe at the flange height maybe a trim type command in Inventor
    2 move the end centre of pipe to the centre of the flange if length is not critical.
    3 shorten pipe to correct length using properties
  7. #7
    Senior Member lulumara's Avatar
    lulumara's Computer Details
    Window 10
    Intel i7
    P&ID
    lulumara's Discipline Details
    Cad Designer/ Draftsman
    P&ID
    Mechanical, Piping draftsman, Structural, Underground electrical distribution designer (civil), Architectural, and more.
    AutoCAD 2017
    Jun 2006
    VANCOUVER,B.C.
    335
    Is this in Assembly files or just in Part files? If Assembly files , you can use constrain- joint(Inventor2016 version) /gap( before using this measure the extra length (command is distance) you need to move in order to flush at the bottom of hole) examples = -.25" or 1/4" or + 0.25" just play around to see it flush to the bottom.
    If a part files-- use sketch to plane parallel to the hole housing/ then extrude cut in order to remove the pipe excess you are seeing.
    Jimmy - using AutoCad 2017 and Solidworks 2009
  1. Pipes & Fittings
    By trajcheblue in forum AutoCAD General
    Last Post: 18th May 2012, 05:24 pm
  2. 3D pipes
    By danieldalio in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th May 2012, 05:42 pm
  3. Drawing 3D-tunnel with pipes
    By CADisEVIL in forum AutoCAD 3D Modelling & Rendering
    Last Post: 28th Jan 2010, 02:35 pm
  4. Pipes & Tubes
    By ankurpraja in forum Autodesk Inventor
    Last Post: 16th Sep 2009, 10:56 pm
Tags for this Thread
