Updated to Version 1.3
This should correct an issue with nested blocks and also allow the user to import Layer States.
Enjoy!
Lee
Updated to Version 1.2 to include UCS/Views and also a handy Search Bar![]()
Lee Mac Programming
Just another Swamper
Enjoy!
Lee
Lee Mac Programming
I have updated this program to Version 1.5
This version implements a number of changes to improve the program:
- Added the ability to use Wildcard Patterns in the 'ItemList' parameter to allow all items in a collection which match the supplied wildcard pattern to be imported.
- Added Materials and Named Viewports to the list of collections.
- Added 'StealAll' command to allow the user to automatically steal everything from a selected drawing file.
- Added 'StealTemplate' command to enable the user to quickly steal items from the QNew template file (or other template file, if the QNew template file is not set).
The latest version can be found here.
Lee Mac Programming
You never cease to amaze us Lee. Thanks for your tireless efforts.
Cheers ReMarkI hope the program is of use to you
Lee Mac Programming
I've run into an issue, I get "Error: Automation Error. Problem in loading application". =/
"The thing about quotes on the internet is that you cannot confirm their validity." - Abraham Lincoln
I -edit- a lot, sorry.
The rotary engine is the most efficient way of converting fuel to noise ever invented.
If my post sounds offensive, but can be meant in a non-offensive manner...I meant the latter.
Lee Mac Programming
AutoCAD MEP 2012
Did I miss somewhere that says it won't work? If I did, my bad.
-Edit- I see where you said you're a vanilla guy. I'll try it on vanilla.
-Edit- Same response/error in vanilla AutoCAD 2012.
That's weird since this is the first I've heard of an error report of this nature (for any version in fact). From the error message you posted I'm guessing the program cannot load the ObjectDBX Document.
Does this return a non-nil value:
Is anyone else having this problem?Code:(vl-registry-read (strcat "HKEY_CLASSES_ROOT\\ObjectDBX.AxDbDocument." (itoa (atoi (getvar 'ACADVER))) "\\CLSID"))
Lee Mac Programming
