Kim Posted January 20, 2011 Share Posted January 20, 2011 I've copy/ pasted a detail from one drawing to another, and now have hundreds of "X-Ref......" scale factors in my VP Scale menu. When I try to use scalelistedit, I get this message: Unhandled exception has occurred in a component in your application. If you click continue, the application will ignore this error and attempt to continue. Index was outside the bounds of the array" When I click continue, nothing happens and the command line refreshes itself. What does this message mean, and how can I fix the problem so that I can use scalelistedit? Second problem - when I try to change the scale of a viewport using my properties manager, I get this message: "Invalid argument scale in setting standardscale property". It won't allow me to change the scale. How do I fix this? Your help would be most appreciated:) Quote Link to comment Share on other sites More sharing options...
