Results 1 to 4 of 4
    Senior Member SwChilly's Avatar
    SwChilly's Computer Details
    Microsoft Windows XP
    Intel(R) Xeon(R) CPU
    Civil 3D 2013
    May 2010
    Sk, Canada
    107
    Question Help! Pipe Network Question
    I'm using AutoCAD Civil 3D 2010.
    I'm new to pipe networks so bear with me. What I'm trying to do is create pipe network from objects. So I go to Pipe Network> Create Pipe Network from Object> then slect my object.... but what if I want multiple objects under the same network?
    If I call multiple objects the same network name, it just adds a counter (ex. Proposed Water, and Proposed Water (1)). I don't want that. I want them all under the same network but different pipes.
    One of our older drawings have mutliple pipes under the same network.. Help!
    I've got another one... is there a way to move a pipe from one network to the next?
    Oh! Also... how do I add a structure to a pipe? The tutorial is way confusing.
    Thanks in advance!
    "Getting information off the Internet is like taking a drink from a fire hydrant."
    Mitchell Kapor
    Forum Deity
    Civil 3D 2008
    Sep 2006
    Pittsburgh, PA, USA
    3,581
    What objects are you using to create the network? You can only use Lines, Polylines, Splines, Arcs & Feature lines
    from Help
    Create pipe networks from existing objects in your drawing.
    Using this method you can automatically create a pipe network from the following types of entities:
    Entity Description
    Line Creates a pipe network from a line that you selected. The pipe network is inserted as a straight pipe with structures at each end.
    2D polyline Creates a pipe network from lightweight or heavyweight 2D polylines.
    2D spline polyline Creates a series of straight line segments using fit points to define pipe endpoints and structure locations. For more information about fit points, see the AutoCAD Help.
    3D polyline Creates a pipe network using vertices in 3D to define pipe endpoints and structure locations. Arc Creates a pipe network from an arc that you selected. The pipe network is inserted as a curved pipe with structures at each end.
    Feature line Creates a pipe network from a feature line.
    using Create Pipe Network from Object will create one network using the vertexes to insert structures with pipes between.
    Civil 3D 2013
    May 2010
    Sk, Canada
    107
    I've got three polylines.. but I can't click them all to make them under the same network.
    Mitchell Kapor
    Forum Newbie
    Civil 3D 2011
    Mar 2011
    1
    have your ever changed the ucs?
  1. Civil 3d Pipe Network Capabilitys
    By baldema in forum Civil 3D & LDD
    Last Post: 5th May 2011, 01:24 pm
  2. Pipe Network Question
    By SwChilly in forum Civil 3D & LDD
    Last Post: 24th Jan 2011, 06:37 pm
  3. Replies: 0
    Last Post: 5th Jan 2011, 01:30 am
  4. Changing Pipe Network Diameters at once
    By Hardney in forum Civil 3D & LDD
    Last Post: 14th May 2010, 08:42 pm
  5. Network license question
    By MikeP in forum AutoCAD General
    Last Post: 11th Mar 2010, 02:25 pm
