+ Reply to Thread
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 23
  1. #11
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Jan 2011
    Posts
    9
    Default
    @kramerO : i already have pipe.LISP from Spaug.org.. but it was not working for me..
    @ReMark : i work in metric system.. actually the pipe is abt 600 mm long and belongs to fuel booster pump in a transport aircraft..it has op temp of abt 200+ deg cel..and has a steel mesh with adapter in the centre (i.e. welded) and at the ends has hex nut and a nipple... finally it is bent in all 3 axis..
    thats why, i am thinking of posting a jpeg..which will help..
  2. #12
    Senior Member
    Computer Details
    paul1966's Computer Details
    Operating System:
    win 7 pro
    Motherboard:
    ASRock AM2NF3-VSTA
    CPU:
    AMD Sempron 3400+ 1.81Ghz
    RAM:
    3 GB
    Graphics:
    NVIDIA Quadro FX1000
    Primary Storage:
    Maxtor 80 GB
    Monitor:
    Samsung 2232BW 22 inch wide screen + 22inch TFT
    Discipline
    HVAC
    Using
    AutoCAD 2010
    Join Date
    Dec 2007
    Location
    Leicester, UK
    Posts
    165
    Default
    Quote Originally Posted by StykFacE View Post
    Great freebie program that does it for you:
    http://www.cadtutor.net/forum/showth...l=1#post375064
    second the above, i use wpipe lisp everyday doing hvac layouts, very neat program.
  3. #13
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,726
    Default
    abc_123: You say pipe.lsp is not working for you. Where are you encountering a problem?
  4. #14
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Jan 2011
    Posts
    9
    Default
    hi all,
    due to site unavilability i could not post the photos... here r the pipes i would like to draw in 2d... pl suggest ways for drawing.. thiPhoto0918.jpgsPhoto0915.jpg.Photo0916.jpg.Photo0917.jpg
  5. #15
    Luminous Being tzframpton's Avatar
    Computer Details
    tzframpton's Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    tzframpton's Discipline Details
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Using
    Revit 2018
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,074
    Default
    I highly doubt a programmer went to the depths of creating a LISP Routine of a catalog of copper pipes, fittings, elbows, steel braided hose, and all in between if you're seeking a high level of accuracy. Things of that detail, you'll have to make your own inventory of blocks of all your fittings and elbows (from any dimensional spec chart of the manufacturers of your company's liking) and just grab them when you need.
    I would look into creating a hierarchy of Tool Palettes to better access these cataloged blocks IMHO. Or you could contact a programmer to create a customized program to fit your company's needs.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  6. #16
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Jan 2011
    Posts
    9
    Default
    actually i am ease at creating steel nut, nipple, steel braided hose and all fittings in between.. but my quality staff is asking me to represent the bends (like angles wrt x, y and z axis).. initially we were making 2 staright lines to represent pipe line.. with a quotation of "bend as per original sample:".. but since quality staff requires more, we dont know how to represent them.. i want only ideas or some sample pipe drawings.. not LISPs.. thanks...
  7. #17
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2018
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    46,726
    Default
    It appears as though a majority of the pipe could be detailed using a single plan view. The small remaining portion could perhaps be detailed using a plan view and at least one side view.
    Do you have any dimensions or angles to work with that you could post here?
    One other option is to construct it in 3D then use one of three methods to extract the 2D views from the 3D object.
  8. #18
    Full Member
    Computer Details
    kramerO's Computer Details
    Operating System:
    N/A
    Using
    not applicable
    Join Date
    Oct 2010
    Location
    N/A
    Posts
    36
    Default
    abc_123,
    Your pics are of tube NOT pipe.
    If I had to draw this for a fitter to make, I would do it single line isometric. That is the easiest way to show and dimension the rolling offsets.
    Pipe.lsp is for pipe. Did you follow the procedure for loading the lisp?
    Better to remain silent and be thought a fool than to speak out and remove all doubt.
    Mark Twain
  9. #19
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Jan 2011
    Posts
    9
    Default
    @ReMark : its abt 410 mm lengeth and has variying angles on all 3 axis.. abt 15 to 20 deg..
    @kramerO : that pipe.lsp i just loaded for trial purpose.. not for this.. but do i have to put all the contents in the resp. folder ?..i think ur method of rep single line seems ok for me..
    @ReMark : any comments on single line isometric ?
  10. #20
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO 64-bit
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x64
    CPU:
    Pentium(R) i5 4570 @ 3.2GHz
    RAM:
    8 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    2x ThinkVision 24"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2018
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    11,955
    Default
    Quote Originally Posted by kramerO View Post
    abc_123,
    Strictly speaking and depending on the country you are from it CAN be called either and be correct. Following is a small portion from Wikipedia, you can read the rest if you like. http://en.wikipedia.org/wiki/Pipe_(material)
    Quote Originally Posted by Wikipedia
    A pipe is a tubular section or hollow cylinder, usually but not necessarily of circular cross-section, used mainly to convey substances which can flow — liquids and gases (fluids), slurries, powders, masses of small solids. It can also be used for structural applications; hollow pipe is far stronger per unit weight than solid members.
    In common usage the words pipe and tube are usually interchangeable, but in industry and engineering, the terms are uniquely defined.
    You could try Loft or Sweep or Revolve or a combination, to create a 3D model, but first you need to practice drawing a path in 3D space. If you know the dimensions and angles, you could use coordinates @ the command line, just remember you will have "z" values. Learn to change your 3D Views and Rotate or use 3D Rotate. The same applies for single line isometric drawings, you just need to practice and get familiar with the commands. There are as many more methods to do this as well. To learn a command use AutoCAD help or search and browse CADTutor.
Similar Threads
  1. Trimming pipes
    By bengee54 in forum Autodesk Inventor
    Last Post: 24th Jun 2015, 10:09 pm
  2. Pipes & Fittings
    By trajcheblue in forum AutoCAD General
    Last Post: 18th May 2012, 05:24 pm
  3. 3D pipes
    By danieldalio in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th May 2012, 05:42 pm
  4. Pipes & Tubes
    By ankurpraja in forum Autodesk Inventor
    Last Post: 16th Sep 2009, 10:56 pm
  5. Using spline with line to draw pipes in 2D
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 14th Nov 2006, 06:57 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
