+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
  1. #21
    Forum Deity rkent's Avatar
    Computer Details
    rkent's Computer Details
    Operating System:
    WIN7 PRO 64bit
    Computer:
    Dell OptiPlex 7020
    CPU:
    i7 4790 3.6GHz
    RAM:
    16GB, 1600MHz, DDR3 non-ECC 2x8GB
    Graphics:
    AMD Radeon 2GB
    Primary Storage:
    Samsung 480Gb SSD
    Monitor:
    Dell 24" FS (2x)
    Discipline
    Mechanical
    rkent's Discipline Details
    Occupation
    Facilities Design - Semi-conductor manufacturing
    Discipline
    Mechanical
    Details
    Designer: Process Piping, P&ID's, Machine Part Design, Planning / General Arrangement. Facilities Management. Drafting: Electrical, Controls, Architectural.
    Using
    Mechanical 2017
    Join Date
    Nov 2007
    Location
    Lat:35, Long:-106, Elev: 5164'
    Posts
    4,598
    Default
    Quote Originally Posted by abc_123 View Post
    hi all,
    i am new to this forum.. and found the posts are really helpful.. basically i am a mech design fellow designing mech parts like coupling, brackets etc.. recently i am tasked to draw pipes.. just pipes with 2 or 3 bends at different angles / axis..
    so ur assistance needed is in ..
    (a) how to draw pipes with bend angles in 2d and dimension them..
    (b) if possible, pl give some sample dwg files..
    thanks in adv..
    Here is an example, note the ellipse used to denote 45s going down, for 90 degree ells use a circle broken the same way. The connection points may need to be shown with an X or filled donuts depending on standards, type of joint (weld, screw, solder), etc.
    Sometimes there's a man... I won't say a hero, 'cause, what's a hero? But sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place. He fits right in there. And that's the Dude, in Los Angeles. - The Stranger, The Big Lebowski
  2. #22
    Forum Newbie
    Using
    AutoCAD 2008
    Join Date
    Jan 2011
    Posts
    9
    Default
    thanks...rkent & all,,,
  3. #23
    Full Member isutheparambil's Avatar
    Discipline
    Electrical
    isutheparambil's Discipline Details
    Occupation
    Designer/Draftsman-Electrical / CAD Coordinator
    Discipline
    Electrical
    Details
    A qualified Electrical CAD Designer Draughtsman with a solid experience in Electrical CAD designing and drafting of Multi-storied building, Shopping complex, Palace, Mosque, Luxury Villas etc. with the design department of multinational companies for the various types of electrical design.
    Using
    AutoCAD 2014
    Join Date
    Jul 2013
    Location
    United Arab Emirates
    Posts
    76
    Default
    Hi Remark,
    Do you have any lisp that converting plines or lines to a pipe and its fittings format, ie with elbow like...
Similar Threads
  1. Trimming pipes
    By bengee54 in forum Autodesk Inventor
    Last Post: 24th Jun 2015, 10:09 pm
  2. Pipes & Fittings
    By trajcheblue in forum AutoCAD General
    Last Post: 18th May 2012, 05:24 pm
  3. 3D pipes
    By danieldalio in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th May 2012, 05:42 pm
  4. Pipes & Tubes
    By ankurpraja in forum Autodesk Inventor
    Last Post: 16th Sep 2009, 10:56 pm
  5. Using spline with line to draw pipes in 2D
    By Siberian in forum AutoCAD Beginners' Area
    Last Post: 14th Nov 2006, 06:57 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
