Results 1 to 2 of 2
    Forum Newbie
    McWaters12's Computer Details
    Windows XP SP 3
    Toshiba Satellite
    1.86 Ghz
    2 GB
    80GB
    500 GB
    AutoCAD 2011
    Jan 2011
    Auburn, AL
    6
    Default Having problems dealing with contours
    I have imported some contour lines into Civil 3D. Each contour line is at 2'. Is there a way for Civil 3D to automatically take each line is set them at 2' increments? If not, I know how to go in and set each poly-line individually, but right now all I can type in are inches, so for 2' I have to type in 24. Does anyone know how to change this? Thanks for any help!
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, Vista and XP Pro
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2013
    Jun 2006
    Saxony, Germany
    857
    Go to the Units format dialog and change the settings from inches to feet and check the settings in Civil 3D Style for the DTM.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
  1. Question dealing with Suffix's in Dimension Styles
    By Vikes_Fl in forum AutoCAD General
    Last Post: 3rd May 2013, 11:16 pm
  2. Dealing with Noobs
    By rustysilo in forum CAD Management
    Last Post: 13th Aug 2009, 02:43 am
  3. dealing with balloons
    By heijunka in forum SolidWorks
    Last Post: 2nd Jan 2008, 12:54 pm
  4. Dealing with gaps
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 27th Apr 2007, 08:40 pm
  5. Dealing with gaps
    Last Post: 22nd Apr 2007, 06:50 pm
