Results 1 to 3 of 3
    Forum Newbie
    McWaters12's Computer Details
    Windows XP SP 3
    Toshiba Satellite
    1.86 Ghz
    2 GB
    80GB
    500 GB
    AutoCAD 2011
    Jan 2011
    Auburn, AL
    6
    Default How do I create a surface using contour lines?
    I have my contour lines and they are each set at their proper elevations. I want to know how to get a surface to 'mold' to the lines.
    Super Member Tyke's Avatar
    Tyke's Computer Details
    Windows 7 - 64 bit, W8 + W8.1 Vista
    HP Z400 Workstation
    Intel(R) Xeon(R) CPU W3530 @ 2.80GHz
    8 GB
    Nvidia Quadro 600 1GB DDR3
    2x 500GB HDD RAID 1 and Western Digital 2TB NAS RAID 1
    Lacie external HDD 2TB Raid Level 1
    Samsung SyncMaster P2770HD, 2443 and 193T
    Multi-disciplinary
    Tyke's Discipline Details
    Surveyor, programmer, civil engineer
    Multi-disciplinary
    Surveying and civil engineering. As built utilities surveys and data maintenance in GIS systems. Building surveys, measured and laser scanning. Setting out of all civil works. Control and settlement surveys. Programming in AutoCAD, MicroStation, Geograf and stand alone applications for all uses.
    Civil 3D 2014
    Jun 2006
    Saxony, Germany
    1,397
    I'll give you something McWaters12, you are persistent
    Do you have Civil 3D?
    If you do first explode your polylines so that they become Lines
    Then create a new Surface.
    Go to the Prospector tab of the Toolspace.
    Open up the Surfaces.
    Open up Definition .
    Right click Drawing Object.
    Click Add.
    In the Drop Down List Objects select Lines.
    Select all your lines on screen.
    Click OK.
    On the Settings Tab open up Surface.
    Open up Surface Styles.
    If you have not created your own style then right click Standard and select Edit.
    Go to the Display Tab and make visible what you want to see.
    Other properties can be set in the various tabs.
    I would not recommend editing ANY Standard Style, but first of all right clicking the Standard style and selecting Copy -give it your own name and then edit that style.
    Post your drawing and say exactly what you want to do.
    Engage brain before mouth
    "The German who types with a Yorkshire accent" - Dave Broada 2o1o
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,040
    Have you tried doing a search? Seems like a similar question came up a few years ago.
  1. Corridor/surface contour creation???
    By JerryG in forum Civil 3D & LDD
    Last Post: 26th Sep 2013, 06:07 pm
  2. Create contour lines
    By Nuttieke in forum AutoCAD Beginners' Area
    Last Post: 7th Aug 2012, 04:46 am
  3. Creating a surface or solid from a Contour Map?
    By Sian in forum AutoCAD 3D Modelling & Rendering
    Last Post: 9th Jan 2011, 06:06 pm
  4. Contour lables on a surface
    By mcjohn in forum AutoCAD Beginners' Area
    Last Post: 21st Jun 2010, 05:55 pm
  5. Contour and Surface
    By nyaromulo in forum Civil 3D & LDD
    Last Post: 18th Aug 2009, 03:13 pm
