Rainy-Day Posted January 30, 2006 Share Posted January 30, 2006 You know how if you have a command running, you can hit 'p'Enter to select previously selected objects? Now, let's say I like to first select objects, then use a command on them.. how can I do the same thing then? I tried select command but that doesn't work 'cause it will deselect all objects it selected right after you exit it.. Please help! Quote Link to comment Share on other sites More sharing options...
Dommy2Hotty Posted January 30, 2006 Share Posted January 30, 2006 PICKFIRST System Variable Type: Integer Saved in: Registry Initial value: 1 Controls whether you select objects before (noun-verb selection) or after you issue a command. 0 Turns off PICKFIRST; you select objects after you issue a command 1 Turns on PICKFIRST; you select objects before you issue a command Command: PICKFIRST Enter new value for PICKFIRST : 1 Quote Link to comment Share on other sites More sharing options...
Dommy2Hotty Posted January 30, 2006 Share Posted January 30, 2006 Really, all you have to do is select the entities, either by single picks or by a window, then issue the command from either the command prompt (keyboard entry) or toolbar button. Quote Link to comment Share on other sites More sharing options...
Rainy-Day Posted January 31, 2006 Author Share Posted January 31, 2006 I'm talking about selecting previously selected objects. e.g. I select 5 objects; I use move command to move them. I hit a shortcut key that selects these same 5 objects; I use copy command to copy them. (or any other command). That's what I'm looking for. I already tried select command but that doesn't work because it deselects the objects after you finish it. Quote Link to comment Share on other sites More sharing options...
CarlB Posted January 31, 2006 Share Posted January 31, 2006 I think you will find that it does not "deselect" your selection after ending the 'select' command, it just no longer highlights them. That selection is still available as the "previous" selection for a subsequent command. Quote Link to comment Share on other sites More sharing options...
Rainy-Day Posted January 31, 2006 Author Share Posted January 31, 2006 I'd like to keep it "highlighted" or selected, so that I could use the next command on it without having to type p and enter *after* a command. It's not that typing p is too hard, (although for something I'd want to use so often even that is a considertion), it's that I always work in a manner of making a selection then running command on it, not the other way around, and it feels uncomfortable to switch the order and then switch it back again. I think there must be some way to keep the objects selected, perhaps some deep autolisp way of doing this.. Thanks! Quote Link to comment Share on other sites More sharing options...
CarlB Posted January 31, 2006 Share Posted January 31, 2006 You could make a button with the following macro. It will highlight & grip the "previous" selection: ^C^C^P(sssetfirst nil (ssget "_P"))(princ) Quote Link to comment Share on other sites More sharing options...
Rainy-Day Posted January 31, 2006 Author Share Posted January 31, 2006 Thanks KarlB, this is exactly what I need.. Much gracias! Quote Link to comment Share on other sites More sharing options...
piyushparihar24 Posted June 3, 2016 Share Posted June 3, 2016 Hi, Once the data is selected and if unknowingly it is deselected, I want to select it again using command, which command should I use? Quote Link to comment Share on other sites More sharing options...
