Deleting un-used block attributes using Lisp
mlcadman
I am looking for some help.. I have a program that inserts a block and within that block there are many attributes. I would like to then have my program delete the un-used attributes. Can someone get me pointed in the right direction?
why do you want to do this?
Once you have the block in the drawing with however many attributes you end up with, you won't be able to insert that block again with a different number of attributes. If you write the code to delete the unused attributes on insertion and your newly inserted block has fewer attributes than your previous block the previous block will be re-defined to the lower number of attributes.
Having said all that it shouldn't be too hard but I have forgotten all the LISP I ever knew so I'll let somebody else answer your question.
