+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Senior Member StevenMc's Avatar
    Using
    AutoCAD 2009
    Join Date
    Mar 2009
    Location
    Glasgow
    Posts
    222
    Default Lines looking the same in MS and PS?
    Hi
    Was wondering if it was possible for me to have my dashed and centre lines constantly looking the same when I'm in MS and PS? at the moment my drawing is set up so that the lines print correctly and look right in PS but when I'm in model space they all look solid which is frustrating for the drawing I'm doing.
    I've had a look around and can't get anything to work
    Also my MSLTSCALE and are set to (1)
    Cheers
    "Leave it on the doorstep and get the hell outta here!"
  2. #2
    Luminous Being tzframpton's Avatar
    Computer Details
    tzframpton's Computer Details
    Computer:
    HP Zbook
    Discipline
    Multi-disciplinary
    tzframpton's Discipline Details
    Occupation
    BIM Specialist
    Discipline
    Multi-disciplinary
    Details
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Using
    Revit 2019
    Join Date
    Mar 2006
    Location
    Dallas, TX - USA
    Posts
    9,115
    Default
    Check your CANNOSCALE settings. Change it to match the scale of your Viewport in PS.
    *EDIT* Also make sure PSLTSCALE is 1.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  3. #3
    Using
    AutoCAD 2009
    Join Date
    Mar 2009
    Location
    Glasgow
    Posts
    222
    Default
    Ok thanks, not been on since the forum was down! Will give it a try tomorrow at work
    Cheers
    Steven
Similar Threads
  1. Solid lines instead of Dashed lines in model and Viewports
    By zionshea in forum Architecture & ADT
    Last Post: 26th Aug 2010, 08:14 pm
  2. remove double lines from drawing(lines,polylines,text)
    By cadamrao in forum AutoCAD Drawing Management & Output
    Last Post: 12th Apr 2010, 02:35 pm
  3. my dash lines print as continuous lines...help
    By talibuhcler in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Mar 2010, 10:59 pm
  4. Constructing Hidden Lines and Construction Lines
    By Colgrave in forum AutoCAD Beginners' Area
    Last Post: 6th Feb 2009, 04:01 pm
  5. Replies: 16
    Last Post: 3rd Dec 2008, 03:45 pm
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
