Results 1 to 2 of 2
    Super Member
    not specified
    Feb 2006
    705
    Default Is there a way to test for a valid drawing file neme before openning a drawing in VBA
    AutoCAD 2010 vba
    In VBA I want to test to see if I have a valid filename before I save a drawing file using
    ThisDrawing.SaveAs Drawingfile. VBA needs to know if it has a valid file name
    "DrawingFile" before trys to save the filename. Is there a way to test for a valid filename in
    vba?
    Thank you,
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,715
    You have the filename just check the characters in it for invalid characters such as !@#$%^&*() no easy way.
  1. Drawing file is not valid!!
    By showa in forum AutoCAD General
    Last Post: 7th Jul 2010, 07:33 pm
  2. Drawing file not valid
    By Alan in forum AutoCAD General
    Last Post: 22nd Mar 2010, 03:11 pm
  3. Drawing file is not valid....
    By rbeldua in forum AutoCAD General
    Last Post: 6th May 2009, 09:48 am
  4. Drawing file is not valid
    By Tin in forum AutoCAD General
    Last Post: 20th Apr 2009, 10:47 pm
  5. Drawing File is Not Valid
    By NiceGuy8618 in forum AutoCAD Beginners' Area
    Last Post: 3rd Jul 2008, 06:12 pm
