Results 1 to 2 of 2
    Full Member
    MikeMc52's Computer Details
    XP
    Dell Precosopm 490
    Dual 24" Dells
    AutoCAD 2012
    Jan 2011
    Houston, TX
    31
    Default Getting information from Non Uniform Blocks
    In the help files it states that objects in non-uniform scaled blocks will not be extracted. If I add an attribute to the block that would contain the information I needed would it be extracted?
    When I draw a 3D pipe, I have three blocks I use:
    Left thread end
    Pipe
    Right thread end
    When I have a 3D pipe to draw, I insert the left thread end (uniform scale), then I insert the pipe block and scale the “Y” to the length I need (minus 2”- one inch for each end) and then I insert the right thread end.
    What I would like to do is add an attribute to the “Pipe” block that would include the length and have that attribute exported so I could use it for the length of pipe to be used to order and construct the pipe. Will this work?
    Full Member
    XP
    Dell Precosopm 490
    Dual 24" Dells
    AutoCAD 2012
    Jan 2011
    Houston, TX
    31
    And the answer is: Even though it probably will not give you a lot of information for an non uniform scaled block it will read the attributes and output them
    And I am happy.
  1. How to get Attribute information for multiple blocks
    By JJtre in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Jun 2015, 07:53 am
  2. Uniform Scale LOCK
    By Handy Man Dan in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 15th Sep 2010, 02:48 am
  3. Uniform distributed load
    By lochie50 in forum Autodesk Inventor
    Last Post: 9th Feb 2010, 03:39 pm
  4. Non Uniform Scale of solid and keep properties
    By itsdoug in forum AutoCAD 3D Modelling & Rendering
    Last Post: 16th Sep 2008, 05:11 am
  5. block attirbute scaling: unifrom vrs non-uniform observations...
    By hazardman in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Feb 2008, 03:35 pm
