MisterJingles Posted February 10, 2011 Share Posted February 10, 2011 Hi all Can someone tell me why sometimes when I trim, the line does not trim back to the first intersection? It trims back to any random point on that line segment. It doesn't matter if its a regular trim, fence trim, it makes no difference. Its a relatively new occurrence and is driving me nuts. Thanks Rob Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 10, 2011 Share Posted February 10, 2011 Maybe if you showed some screen shots, my trimming works fine. Circles and arcs need to be regen to show the exact edge of trim. Quote Link to comment Share on other sites More sharing options...
paulmcz Posted February 10, 2011 Share Posted February 10, 2011 Try to set Edgemode to 0 Quote Link to comment Share on other sites More sharing options...
nestly Posted February 10, 2011 Share Posted February 10, 2011 Yep, sounds like EDGEMODE Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted February 14, 2011 Author Share Posted February 14, 2011 Thanks SLW, I was regenning but with no luck. EDGEMODE was set to 1, thanks guys. Why would one set EDGEMODE to anything but the value which would trim back to nearest intersection? Quote Link to comment Share on other sites More sharing options...
nestly Posted February 14, 2011 Share Posted February 14, 2011 Why would one set EDGEMODE to anything but the value which would trim back to nearest intersection? Check the video called "Trim and Extend with an Edge" (6th one from the top) at http://www.cadalyst.com/video Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted February 14, 2011 Author Share Posted February 14, 2011 Thanks Nestly. I still don't see why it would be kept on as a default but maybe its just because my current line of work doesn't require that option to be on. Thanks again Quote Link to comment Share on other sites More sharing options...
nestly Posted February 14, 2011 Share Posted February 14, 2011 I use EDGEMODE for basically the same reasons shown in the video' it's a quick and easy way to create precise intersections and breaks that's quicker than stretching or grip editing the individual lines. BTW, did you know that holding down while using the TRIM command temporarily changes the mode to EXTEND, and vice versa.... very handy for extending something like a wall, and then trimming out the intersection without having to switch between EXTEND to TRIM commands. Quote Link to comment Share on other sites More sharing options...
MisterJingles Posted February 16, 2011 Author Share Posted February 16, 2011 I didnt know that ... Very handy. Quote Link to comment Share on other sites More sharing options...
NaeKid Posted February 16, 2011 Share Posted February 16, 2011 I use EDGEMODE for basically the same reasons shown in the video' it's a quick and easy way to create precise intersections and breaks that's quicker than stretching or grip editing the individual lines. BTW, did you know that holding down while using the TRIM command temporarily changes the mode to EXTEND, and vice versa.... very handy for extending something like a wall, and then trimming out the intersection without having to switch between EXTEND to TRIM commands. Do you mean that you type TRIM in caps on the command-bar or you hold the shift-key while trying to find the button? Personally, I have no clue where the button is, I use the command-line controls 99% of the time. Quote Link to comment Share on other sites More sharing options...
nestly Posted February 16, 2011 Share Posted February 16, 2011 Do you mean that you type TRIM in caps on the command-bar or you hold the shift-key while trying to find the button? Personally, I have no clue where the button is, I use the command-line controls 99% of the time. While you're in the trim command, if you press and hold down , AutoCAD will switch from Trim mode to Extend mode, so any objects you click on while the shift key is depressed will not be "trimmed" back to the next cuttting edge rather they'll be "extended" to the next available cutting edge. If you read the command line during Trim or Extend, it actually tells you about this trick. demo http://www.screencast.com/t/qkfcmx8r Quote Link to comment Share on other sites More sharing options...
