Results 1 to 3 of 3
Thread: 3D orbit
    Forum Newbie
    not specified
    Feb 2006
    1
    Default 3D orbit
    hey guys
    i have some experience in cadd 3d, and now im moving to some arc desktop 3d, which is pretty much identical. im running into a really annoying problem. i use 3d orbit, and after a while it seems like one of the axis jst stops working in orbit. if i go left and right it orbits along the x axis, and if i go up and down it does the same. its fine when i start a new drawing but i cant fix my other started drawings. i opened it into cadd and the orbit works fine. if anyone can help me it would be greatly appreciated.
    Junior Member
    not specified
    Mar 2006
    Fort Fairfield, ME
    19
    Default 3d orbit
    I've had the same problem, all I did was right click while in 3d orbit, go down to projection, and select perspective. Then do the same thing and change it back to parellel.
    Hope this helps
    Senior Member daveyboyd's Avatar
    AutoCAD 2010
    Apr 2006
    Liverpool, UK
    127
    I am having the same problem, any one solved this yet?
