QualityEngineer Posted February 16, 2011 Share Posted February 16, 2011 Hi all, Right then, this is my first real job using AutoCAD since taking the decision to abandon manual drafting some months ago. I'm, annotating a drawing for a F1 Car Development House and am specifying the All round surface finish of the product and can't seem to find the right annotations for it. For those not entirely sure what i'm on about, here's a drawing of the annotation. Ive tried using a leaderline and changing the arrowhead, but the annotation graphic is not there at all and i've basically resigned myself to manually annotating this by designing the graphics myself but, before I do, is this graphic present or do I have to draw manually and if so, is there a way of storing this custom graphic for use later like a macro? Thanks QE Quote Link to comment Share on other sites More sharing options...
designerstuart Posted February 16, 2011 Share Posted February 16, 2011 not the answer you're looking for but if all else fails you could draw what you want as a block with an attribute? this would make it accessible to easy use and repeatable. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 16, 2011 Share Posted February 16, 2011 Surface finish annotations are not a normal part of AutoCAD. Create a normal block or even a dynamic block and put it on a new Tool Palette for future use along with any other custom blocks you may find yourself needing on a continuing basis. Quote Link to comment Share on other sites More sharing options...
QualityEngineer Posted February 16, 2011 Author Share Posted February 16, 2011 Ok easy enough, cheers guys. Are they part of any AutoCAD design suite or is this a blanket no. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 16, 2011 Share Posted February 16, 2011 My guess is that Inventor would likely have this type of annotation but since I don't use the program I'm not 100% certain. Quote Link to comment Share on other sites More sharing options...
QualityEngineer Posted February 16, 2011 Author Share Posted February 16, 2011 ok cool. Would it be helpful to anyone if I design these to ASME standards, then post them here if anybody else needs them? Or is that not allowed by AutoDesk and/or yourselves... Thanks QE Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 16, 2011 Share Posted February 16, 2011 I can't see where that would be a problem for AutoDesk. As for CADTutor, I don't see that as being a problem either but that's entirely up to the moderators and the site's owner. People post all kinds of drawings as well as lisp routines, hatch patterns, fonts, and alike. I think the only real problem is CT does not have a dedicated area for content such as this. It's been a topic of discussion in the past. Quote Link to comment Share on other sites More sharing options...
designerstuart Posted February 16, 2011 Share Posted February 16, 2011 i think you should post it - nicely completes the post. thanks for sharing! Quote Link to comment Share on other sites More sharing options...
QualityEngineer Posted February 16, 2011 Author Share Posted February 16, 2011 Well, If they are of any use to anyone, here are all the surface tolerance indicator graphics done in blocks to ASME and ISO standards. Considering the amount of work i've just seen thats come in, ill be using these ALOT!!!!! Hope they are helpful,, QE Basic-surface-finish.dwg Approx-circular-surface.dwg Surface-to-be-machined.dwg All-round-to-be-machined.dwg Crossed-in-2-oblique-directions-to-plane-of-projection.dwg Material-removal-not-allowed.dwg Perpendicular-to-plane-of-direction.dwg Material-removal-not-allowed-all-round.dwg Parallel-plane-of-direction.dwg Multi-Directional-Surface.dwg Approximate-radial-surface.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 17, 2011 Share Posted February 17, 2011 Thanks for sharing. Now I'll share with you. Find ANSI Y-14.5 surface finish symbols here. Download the FINISHSM.ZIP file. http://www.insa.com/files/Mechanical%20ACAD.shtml Quote Link to comment Share on other sites More sharing options...
QualityEngineer Posted February 17, 2011 Author Share Posted February 17, 2011 OOOOOOHHHHHH!!!!!! Lots of good stuff. Cheers for this, thisll keep me busy at the weekend!!! sure wifey will love this one... Quote Link to comment Share on other sites More sharing options...
