Results 1 to 5 of 5
    Full Member ChrisGrady's Avatar
    ChrisGrady's Computer Details
    Dell Optiplex
    Dell E2310H
    AutoCAD LT 2008
    Sep 2010
    Bolton, UK
    40
    Default Inserting Blocks
    I am having a right torrid time with this drawing first of all the seat numbers (see previous post!!) and now I can't insert a block!!
    I select insert block and the dialogue box comes up - I then pick the block that I want and I check the insertion point box to specify on screen but uncheck the scale specify on screen and set it to 1.0 which is the same as the block unit, I then click ok and select a point on the drawing where I would like the block to go by clicking my left mouse button and nothing happens!!!
    I have tried upping the scale of the block but this still does not work!! HELP!!
    I am using 2009 LT by the way
    All I can say is 'have a lovely time!!'
    Super Member
    designerstuart's Computer Details
    xp
    various
    Architectural
    designerstuart's Discipline Details
    architect
    Architectural
    ADT 2009
    Jun 2010
    near london, near europe
    756
    layers on? does it work with other blocks? check it's in the drawing (i use rename - block is the name in the list?)
    Dell Optiplex
    Dell E2310H
    AutoCAD LT 2008
    Sep 2010
    Bolton, UK
    40
    Thanks Stuart - I have used this block before and had no problem! I tried what you have suggested and it is in the drawing, I also tried some other blocks and they are going in fine but the only difference is that the block units in the other blocks are set to unitless and the block I'm struggling with is set to millimeters - I presume I can change this in block editor?
    Senior Member Rebel's Avatar
    Rebel's Computer Details
    XP
    AutoCAD 2012
    Apr 2007
    Las Vegas
    138
    try running quick select to see if they are in model space, perhaps just too small to see due to the scale issue?
    qselect is the command, it will bring up a window and under object type select "block reference", then under properties find "name", and under value select the block you are having issues with. If they are there it should select every instance of the block.
  5. #5
    Dell Optiplex
    Dell E2310H
    AutoCAD LT 2008
    Sep 2010
    Bolton, UK
    40
    Rebel - thats a great trick!! I like it! I have found them all and your right it is a scale issue they are too small to see!!
  1. Inserting Blocks
    By Ndape in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jul 2008, 02:41 am
  2. Inserting Blocks Using VBA...
    By rajeshjm in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Jul 2008, 07:15 pm
  3. Inserting Blocks
    By Michael Henson in forum AutoCAD Drawing Management & Output
    Last Post: 6th Feb 2008, 04:00 pm
  4. Inserting Blocks
    By johnengineer in forum AutoCAD General
    Last Post: 16th Mar 2007, 04:53 pm
  5. Inserting blocks
    By misha in forum AutoCAD General
    Last Post: 1st Jun 2006, 02:33 am
