ChopS Posted February 17, 2011 Share Posted February 17, 2011 I have win7 x64 home edition, i have just installed autocad 2010 w/o any problem but i start the program, everything looks fine, i can type command, set options but when i try to use/select any command (line, tools etc.) in UI, my acad stop working, its not responding. Any1 has same problem? Mb solution? (im using alienware m11x, i7 cpu 4gb ram i guess system req shouldn't be problem) Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 17, 2011 Share Posted February 17, 2011 No problems during installation? You could try the REPAIR option first. Look in Windows under the Add/Remove Programs feature. Did you also install Update 1? Quote Link to comment Share on other sites More sharing options...
ChopS Posted February 17, 2011 Author Share Posted February 17, 2011 I tried repair, same problem. When i installed i updated too, that can be problem? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 17, 2011 Share Posted February 17, 2011 Installing an update should solve problems not create them. You may have to resort to uninstalling then reinstalling AutoCAD. AutoDesk has a recommended procedure to follow when doing this. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 17, 2011 Share Posted February 17, 2011 You might try a different profile with AutoCAD. From the AutoCAD shortcut on the desktop make a copy of the shortcut, right click, pick properties, Shortcut tab, Target line, go to the end of that target statement, is there a "/p name" portion? Replace that with /p new or add that if there is no /p switch. The /p tells autocad to use a particular profile, telling it to use /p new (any random name will work) will cause the program to create a new profile. Pick OK, now Double click on that shortcut and try the UI again. Because typing commands works but the UI doesn't causes me to suspect a problem with a path in the profile you currently use. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 17, 2011 Share Posted February 17, 2011 I'm not understanding how it could be a pathing problem on a new installation. Quote Link to comment Share on other sites More sharing options...
rkent Posted February 17, 2011 Share Posted February 17, 2011 Sometimes we aren't given all the pertinent facts so thought it might be worth the minute it takes to try. "There is logic and then there are computers." Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted February 17, 2011 Share Posted February 17, 2011 Open your Task Manager, look for WSCommcntr*. If it's running, kill it. Any difference? To cure forever, see: http://otb.manusoft.com/2009/03/disable-infocenter-in-autocad-2010.htm Quote Link to comment Share on other sites More sharing options...
ChopS Posted February 17, 2011 Author Share Posted February 17, 2011 You might try a different profile with AutoCAD. From the AutoCAD shortcut on the desktop make a copy of the shortcut, right click, pick properties, Shortcut tab, Target line, go to the end of that target statement, is there a "/p name" portion? Replace that with /p new or add that if there is no /p switch. The /p tells autocad to use a particular profile, telling it to use /p new (any random name will work) will cause the program to create a new profile. Pick OK, now Double click on that shortcut and try the UI again. Because typing commands works but the UI doesn't causes me to suspect a problem with a path in the profile you currently use. I tried but still not working... I had Acad and Inventor 2011 before but these had the same problem. Quote Link to comment Share on other sites More sharing options...
