Patrick Jones Posted February 18, 2011 Share Posted February 18, 2011 Recently i changed the layer color for a drawing in AutoCAD. However, each time i would use one of my layer states, the layer would change to the previous color. SOLUTION: Since i use layer states quite frequently, i keep a drawing with them saved in a prototype directory. All i had to do to fix the problem above was re-save the layer states with the new layer color. And then export them out as files (if you use layer states as often as i do, you know what I'm talking about). Hope this helps! Patrick Quote Link to comment Share on other sites More sharing options...
Organic Posted February 18, 2011 Share Posted February 18, 2011 Are you perhaps accidentally changing the layer viewpot override in a viewport? Quote Link to comment Share on other sites More sharing options...
Patrick Jones Posted February 21, 2011 Author Share Posted February 21, 2011 No, I havent worked with that feature. This would occur even when i wasn't using viewports. Quote Link to comment Share on other sites More sharing options...
