Results 1 to 8 of 8
    Forum Newbie
    AutoCAD 2011
    Feb 2011
    Buffalo, NY
    2
    Default two viewports onto one paper space?
    Hi, I'm not sure if this is the right place to ask, but please do move thread where appropriate.
    I'm trying to figure out if it's possible to add another 'window' because I want two viewports that has different scale. For example, I have an elevation of a bathroom and a detail section and I'd like the detailed section to be right next to it, kinda of like zooming onto one area.
    Say, I'd like that elevation to be 1/8" =1'-0 on a 11by17 paper but the detail to be 1/4"= 1'-0" or something
    Is it possible or is there an alternative to this?
    Help would be greatly appreciated.
    Thanks in advance
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,372
    Quote Originally Posted by vanglak View Post
    Thanks in advance
    Use MVIEW and make as many viewports as you wish, set each one up with any viewport scale you like.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,785
    Further to Rkent make as many as needed you can overlap viewports put a small one inside a big one use a circle as a viewport, use polygon shape.
    Forum Newbie
    AutoCAD 2011
    Feb 2011
    Buffalo, NY
    2
    Thanks! But how do you pan and zoom in within that viewport. It seems to focus only the first viewpoint
  5. #5
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,641
    That is why I usually don't make viewports overlap one another (or resize and scale the second viewport off to the side initially before moving it over the main one) . You could put them on different layers (Viewport_temp say) so you can freeze one, work on the inside vp, unfreeze that other layer then put them all back on a Viewport layer set to not print etc (so the border doesn't print).
  6. #6
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,058
    There is a maximum limit to the number of viewports allowed in a layout and that is 64. I believe the default setting is 15 if I recall correctly. To exceed that number one must change the setting for the system variable MAXACTVP.
  7. #7
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    vanglak, to answer your question directly, put your crosshairs in the viewport you wish to work inside of, and double click. when you finish, you can either use the PS command, or double click somewhere outside the viewport to go back to paperspace.
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
  8. #8
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,224
    "Ctrl + R" rotates through visible viewports.
    Rob
  1. Viewports, Model and Paper space
    By mwbeatty in forum AutoCAD Beginners' Area
    Last Post: 6th Oct 2010, 10:43 pm
  2. viewports in paper space.
    By starman in forum AutoCAD Beginners' Area
    Last Post: 28th Jun 2010, 09:24 pm
  3. Colour Polylines in paper space, black and white in Viewports
    By MarkCalvert in forum AutoCAD General
    Last Post: 25th Apr 2010, 09:21 am
  4. Plotting 4 Different Viewports in Paper Space
    By Mikey77577 in forum AutoCAD Beginners' Area
    Last Post: 6th Nov 2007, 07:33 pm
  5. setting viewports scales from model to paper space
    By RDHOS in forum AutoCAD Beginners' Area
    Last Post: 7th Jan 2005, 08:41 pm
