Results 1 to 3 of 3
    Forum Newbie
    not applicable
    Feb 2011
    5
    Question Export single layer issue
    Hi, I have an auto cad file which has around 100 different layers, I want to extract one layer to a dxf file. I have frozen all layers accept the layer I require and have then tried to use the dxf out command, however the created dxf file still contains all of the other layers. Is dxf out the correct command or am I doing something wrong?
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,083
    It is a pity that you do not say what version of AutoCAD you are using, then you could get a definitive response.
    However, when saving to a DXF file, there has always been an option to select the objects to save.
    In my version, a dialogue box opens up, and in the top right hand corner, there is a Tools option. When I click on the down arrow, then I can go to Options, then DXF options and choose 'select objects'.
    Forum Newbie
    not applicable
    Feb 2011
    5
    Good point about the version, currently trying autocad 2011. I will try what you've said to see if I can see the options. Thanks
  1. Select all objects in a single layer: how?
    By Sudan in forum AutoCAD Beginners' Area
    Last Post: 15th Sep 2015, 08:21 pm
  2. Single polyline on more than one layer
    By eldon in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 24th Jan 2011, 09:43 am
  3. Plotting a Single Layer in COLOR
    By Cbraunheim in forum AutoCAD General
    Last Post: 6th Jan 2010, 02:59 am
  4. Single line text export to .csv
    By closedflat in forum AutoCAD Drawing Management & Output
    Last Post: 28th Aug 2007, 12:06 pm
  5. Question on a Single Layer
    By CarlTonDor in forum AutoLISP, Visual LISP & DCL
    Last Post: 30th Jul 2007, 10:24 am
Tags for this Thread
