Results 1 to 10 of 10
    Forum Newbie
    AutoCAD not applicable
    Feb 2011
    5
    Unhappy Coordinates in AutocAD
    Hi. I have a dxf file from a client created using autocad. I have no idea what these coordinates mean -40 558.37E and -46 244.43 N. These are UTM? I need to convert to decimal degrees. How do I do this??
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows 10
    Architectural
    CyberAngel's Discipline Details
    Civil Drafter
    Architectural
    Roofing and Waterproofing
    AutoCAD 2014
    Jul 2006
    Anywhere Else
    1,205
    Without more information, it's hard to tell what's going on. Do those coordinates belong to a point or a line? Is the space a separator, the way they use a comma in the US, or are there actually four numbers? By "decimal degrees" do you mean you want latitude and longitude or surveyor's bearings?
    It's possible to import points that are given as northing and easting, then redefine your units as lat/long.
    breaking AutoCAD on a regular basis since 1991
    Forum Newbie
    Feb 2011
    5
    Embarrassed coodinates in AutoCAD to decimal degrees
    Thanks for replying so soon.
    I managed to extract the data into excel and this is what I got. All the coordinate values are of this format which I assume is an autocad format. I do not have AutoCAD so I cannot do any conversions using AutoCAD. I want to work in decimal degrees as I have to project the coordinates (be it lines, polygons, etc) in google earth as well as add it to my database which accepts decimal degrees. Your help is appreciated. Thanks.
    x y
    -38034.2924163296 -48867.3372111626 0 0 SiltTraps
    -38013.678428361 -48847.8046473652 0 0
    -37996.5068603859 -48832.2203675267 0 0
    -37964.8317044261 -48828.9999965541 0 0
    -37946.2132784493 -48834.7376294894 0 0
    -37906.8326254954 -48848.147311339 0 0
    -37838.5683475833 -48844.9691993583 0 0
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    It is quite unusual to have negative coordinates in a UTM system. The datum of each zone is chosen so that all coordinates are positive.
    Could you reveal where in the world the site is, and someone might get some inspiration
  5. #5
    Forum Newbie
    Feb 2011
    5
    datum is Lo 31, coordinate system clarke 1880. It is in africa. I just cant seem to understand these values. At a total loss
    Please help!! The above values are x and y coordinate values. But What coordinate values I have noooo idea!!
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    Does this look like the place? Not very good resolution in Google Earth.
  7. #7
    Forum Newbie
    Feb 2011
    5
    0°25'42.88"S
    30°38'59.16"E
    These are the exact coordinates
  8. #8
    Forum Newbie
    Feb 2011
    5
    Rather the coordinates fall witin this area. ;-)
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    4,131
    I have run out of inspiration, but using Google Earth, your coordinates are about 38000m west of 31degreesE and 48000m south of the Equator.
    The central meridian of zone Lo31 is 31 degrees east. Usually the central meridian is given a coordinate of 50000e so that coordinates do not go negative. As I have only worked in the Northern Hemisphere, I have only been using positive coordinates.
    So I would guess that your coordinates are in metre units from a point 31°E on the Equator. Negative going Westwards, and Southwards. I am not sure why you have 10 places of decimals, rather too many for practical use.
  10. #10
    Forum Deity Jack_O'neill's Avatar
    Jack_O'neill's Computer Details
    xp
    Architectural
    Jack_O'neill's Discipline Details
    Architectural
    The bulk of my business is commercial curtainwall, site plans and floor plans. I do occasionally get a bit of tool and die, and the odd house now and again.
    AutoCAD 2010
    Sep 2008
    lost in the Arkansas wilderness
    2,146
    If someone on here has Autocad Map 3d, you could get them to convert your coordinates from the Clarke 1880 system to WGS 84 according to this: http://forums.autodesk.com/t5/AutoCA...4/td-p/2535281. Failing that, there is a converter here http://www.rcn.montana.edu/resources...ordinates.aspx
    As a side note, the Clarke 1880 system is also referred to as the "Cape" coordinate system for those who might be more familiar with that term.
    Never try to teach a pig to sing. It wastes your time and annoys the pig. -Robert Heinlein
  1. Export Coordinates from AutoCAD Help
    By Kcks in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Nov 2010, 11:25 am
  2. Autocad Coordinates
    By damian in forum AutoCAD Drawing Management & Output
    Last Post: 14th Oct 2009, 07:20 pm
  3. AutoCAD coordinates
    By cabltv1 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Jan 2009, 01:36 am
  4. Using Coordinates in AutoCAD
    By crashoveride in forum AutoCAD Drawing Management & Output
    Last Post: 20th Jan 2006, 11:33 pm
