Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 57
    Full Member
    mlbuxbaum's Computer Details
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    Default plot has thick lines not on drawing ?
    Hey all,
    I completed a drawing for class, and on the screen it looks great. When i go to print it and preview it after centering, picking scale, etc, the preview shows most of the text to be thick. Its like the line weight is wrong or something.Drawing7-1.dwg
    i think i have attached the drawing. Let meknow if it doesnt work.
    Thanks again.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    Did you assign lineweights to layers in your drawing?
    Did you use poylines and give them a width?
    Did you check your ctb or stb plot style file?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    OK, I took a look at your drawing. I'd forget about printing for the moment. You have far greater problems in the way you did this drawing. How many classes did you skip?
    For example, the bottom line of your titleblock might look like a single line but there are actually SIX separate lines, one sitting atop the other. Why is that?
    Full Member
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    you just made my day with that.....I can see the humor in it. Ive only had 3 classes so far. I think i already commented on the quality of my instructor. We had never done any text entering or editing before this last class, then he says you have 30 minutes to complete drawing 7-1..... The entire class is frustrated with this guy. I was going to drop the class and take it at another college, but now i want to prove to myself that I can do it even if he isnt that of a good teacher. Dont take that staement the wrong way, I am 100% certain that he knows what he is doing, he just lacks the skills to TEACH it. Anyway.....
    I will redo the drawing before class on Saturday. Most of what i have learned to do has been by trial and error and this site's tutorials. I started this drawing at the bottom right hand corner and drew almost all the boxes seperately. I was in a rush and should have thought about it more than i did. I new at this.
  5. #5
    Full Member
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    i fixed all the multiple lines in the drawing.....wow, i'm not real bright.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,630
    Here are some other things to work on.
    You put everything on Layer 0. I would recommend you set up layers for objects (like linework) and for text.
    Some of your text is annotative; some is not. Why?
    Some text has a linetype of Hidden. Were you aware of that?
    Your viewport scale is 0.4314 which is a bit odd. What scale were you going for?
    Your viewport display is not locked. It's way too easy to mess the scale up with it being unlocked.
    Your viewports shoud be on their own layer and the layer should be set not to print.
    You used one Text Style (Standard) but used a multitude of Font names. Not a good practice.
  7. #7
    Full Member
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    You put everything on Layer 0. I would recommend you set up layers for objects (like linework) and for text. -noted, thank you. I'll give that a shot
    Some of your text is annotative; some is not. Why? I wasnt aware of that. I assume it should be standard then?
    Some text has a linetype of Hidden. Were you aware of that? -no i wasnt
    Your viewport scale is 0.4314 which is a bit odd. What scale were you going for? -not sure, but the drawing is supposed to be 1:2. I will look into that as well
    Your viewport display is not locked. It's way too easy to mess the scale up with it being unlocked. - I will look into that too
    Your viewports shoud be on their own layer and the layer should be set not to print. - okay
    You used one Text Style (Standard) but used a multitude of Font names. Not a good practice. - there were alot of font names, heights and alignments called for on the drawing. Looks like i still have ALOT of things to work on......alot
    Thanks for your help. I will redo the entire drawing tonight, and repost it in the morning, if you dont mind.
  8. #8
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,882
    Seems like you have 1mm thickness. Just work on getting setup properly, after that things will be a little smoother.
  9. #9
    Forum Deity Organic's Avatar
    Civil
    AutoCAD not applicable
    Feb 2009
    2,338
    Further points:
    - Text line space factor should be at even rounded numbers say, not 0.4167 etc
    - Zoom extents and the 'Drawn By' text appears to be out of place/not in its intended location I imagine
  10. #10
    Senior Member daft vader's Avatar
    MEP 2008
    Jul 2006
    uk
    171
    Also my friend when posting here try to save to 2004 so everyone can open it in older versions of autocad (unless it is something that older versions cant do), as not everyone has 2011 like me lol
  1. Thick lines on plots
    By maffpunton in forum AutoCAD Drawing Management & Output
    Last Post: 18th May 2010, 06:49 pm
  2. Thick lines in plot preview
    By stahlhelm79 in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2009, 03:27 pm
  3. layout display thick lines
    By enelram in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Dec 2008, 06:35 am
  4. thick lines
    By takaki in forum AutoCAD Beginners' Area
    Last Post: 4th Nov 2008, 06:48 pm
  5. HELP... Lines turned thick in viewport.
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2006, 02:40 pm
