Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 57
  1. #21
    Full Member
    mlbuxbaum's Computer Details
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    Quote Originally Posted by ccowgill View Post
    depends on what you mean by the center, for a rectangle, I can snap to the center by clicking 2 opposite corners and having AutoCAD find the midpoint between the 2 points.
    hmmmm....thats exactly what i did too....
  2. #22
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    You can use a command modifier like M2P to snap to the center of a rectangle. A command modifier is used in conjunction with another command. Used by itself AutoCAD would tell you it is an unknown command but use it with Move, Copy, Line, etc. and you'll see that it does work quite nicely.
  3. #23
    Full Member
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    that works awesome.....thank you
  4. #24
    Full Member
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    Alrighty then.....i redid the drawing from scratch, and i must say i was much more confident with my techniques. Drawing7-1 revised.dwg
    Please advise as to any errors that are noticeable to your trained eyes.
  5. #25
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I found one segement of a line to the left of the word Scale.
    It appears there might be a line missing on the left where the word Tolerances is.
    It seems you do not want to create/use separate layers for your linework and your text and instead you leave it all on layer "0". That is not what I would recommend but.....
    It seems as though you'll have a Text Style (ex. - Standard) and then override the Text Font that is used thus having a situation where two strings of text are identified as having a Text Style of Standard but be depicted with two different fonts. Is that how you were taught to do it?
    Are you familiar with the PURGE command? You have the Hidden linetype loaded but no longer referenced in your drawing. The linetype definition can be purged (eliminated) from the drawing using the PURGE command.
  6. #26
    Full Member
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    i just looked at the PURGE command. I did not know about that.
    The text font issue, is most likely my doing. I created, under "manage text styles", texts that i would be using numerous times in the drawing. so now under 'manage text styles" i have 6 differents styles. Standard, Annotative, and the 4 I created using the "new" command in the 'text style" menu box. We werent taught that per se.
    The layer issue I havent tackeled yet. I am not sure how to do that. If you are suggesting that i do it with layers I'm sure that is what i should be doing. I will be doing another drawing tonight and tomorrow. I will do it with layers.
    I cannot find the line segment to the left of scale. The half line under tolerances is supposed to be like that.
    Thank you for all your help so far.
  7. #27
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    I was looking for a horizontal line under Tolerances but I guess one is not required.
    The small line segment I referred to is covered by the long bottom line of your title block. That's probably why you can't see it.
    Layers can be an effective way of managing content. You should be able to create a new layer, set its color and assign a linetype to it for starters all by using the Layer Properties Manager. Other options include being able to assign a lineweight to a layer and setting a layer to "no print". Layers can be turned Off/On or they can be Frozen/Thawed. It is also much easier to organize a drawing if one uses layers. For example, let's say you work for an architectural firm. Your drawing could have layers for the foundation, walls, dimensions, windows, doors, electrical, plumbing, the roof just to name a few. You can turn some layers off (or freeze them) while you work on other layers.
    By the way, most long-time CAD users do not draw on layer 0. This is the layer one normally creates their blocks on.
  8. #28
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    11,947
    I used OVERKILL to get rid of the line, it may be an Express Tool, I just type it in. I often do my initial drawing on layer 0, because usually I am making a block. I would draw the title block on layer 0 as well (yes, because I will be making it an attributed block).
  9. #29
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,721
    Yes, OVERKILL is an Express Tool. mlbuxbaum: Are you familiar with Express Tools?
  10. #30
    Full Member
    windows 7
    AutoCAD 2011
    Feb 2011
    Abingdon, MD
    31
    not really, I have seen the tool tab at the top of the screen though. I just looked at it. Pretty cool options in there. I will have to play with that today and over the weekend. I like "delete duplicates" aka Overkill. Really wish i knew about that sooner....would have been a huge help.
    Here is another drawing i have to hand in tomorrow. I think its okay, but then again i didnt think the previous drawing had that many issues.
    All in all i would say im not doing too bad for only 3 classes with an instructor i cant understand. Once again, thanks for everyones help and advice. I really do appreciate it.
  1. Thick lines on plots
    By maffpunton in forum AutoCAD Drawing Management & Output
    Last Post: 18th May 2010, 06:49 pm
  2. Thick lines in plot preview
    By stahlhelm79 in forum AutoCAD Drawing Management & Output
    Last Post: 31st Oct 2009, 03:27 pm
  3. layout display thick lines
    By enelram in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th Dec 2008, 06:35 am
  4. thick lines
    By takaki in forum AutoCAD Beginners' Area
    Last Post: 4th Nov 2008, 06:48 pm
  5. HELP... Lines turned thick in viewport.
    By JBullseye74 in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2006, 02:40 pm
